jjrsmp12
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 22, 2005 - 8:40 pm: | |
Was going to check fluid level in my 5speed manual transmission. I didn't know what model of trans I had, so looked around and it says T-905-M. I assume this is an Eaton/Fuller, but under the clutch access cover, it says Spicer on the clutch. Would this be the original clutch? |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 23, 2005 - 8:08 am: | |
spicer is the correct trans./clutch... |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 23, 2005 - 4:26 pm: | |
Fuller tranny, Spicer clutch. Your "M" gear set is around 5.45 1st, 3.25 2nd, 2.04 or soosss 3rd, 1.32 4th and 1.00 5th. |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 23, 2005 - 8:14 pm: | |
Henry's right, TD. Eagles & MCIs with 4-speed sticks used a Spicer 8844 tranny w/ a Spicer clutch mechanism. Eagles & MCIs with 5-speed manuals used Fuller transmissions with the Spicer clutch. This was OEM. . . HTH, RJ PD4106-2784 Fresno CA |
jjrsmp12
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 24, 2005 - 12:28 pm: | |
Yes it does help. I appreciate the info. Thanks |
