Frank Allen
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 29, 2005 - 12:51 pm: | |
does anybody know where to find dinesuer boards?? ive heard about these for a while but dont know where to find them, thanks Frank Allen 4106 |
James Maxwell (Jmaxwell)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 29, 2005 - 1:06 pm: | |
Just replaced factory board in HWH recently; found it at 3 different local RV repair shops, prices vary 10-25% at retail; I think it was $105.00. Same board for furnace, hwh, frig. Has a resistor that u cut for instant fire. I think RonTheBusnut sells them also. Don't know if it is still made or not, but Ruby Board is also a good aftermarket replacement. |
Sean Welsh (Sean)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 29, 2005 - 1:20 pm: | |
The correct spelling is Dinosaur (just like the prehistoric animal), and a web search will turn up many vendors. I have found MarksRV.com to have good pricing on these in the past: http://www.marksrv.com/dinosaurelec.htm I think you will find the Dinosaur board to be the best on the market, and much superior to the OEM boards. When I had a stick-and-staples, I replaced my Dometic board twice before switching to Dinosaur, and never had to replace it again. -Sean |
Frank Allen
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 29, 2005 - 3:30 pm: | |
Thanks all, sorry about the spelling, been out of school a long time Frank Allen |
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 29, 2005 - 4:22 pm: | |
Frank, what do you need it for? We have one we took out of our Dometic that went bad this spring. The board performed perfectly. We got one trip (two weeks) use out of it before the Dometic rusted out. If ours is the one you need, we can save you some money. Tom Caffrey PD4106-2576 Suncatcher |
Frank Allen
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 29, 2005 - 11:12 pm: | |
Tom , thanks for the offer, but its for a onan gen set ive been working on, it has a small voltage reg inside to charge the batt, has three wires going to it, two a/c and one b+ thats what i need. it is a onan part but has no number on it. says onan 14 volt 20 amp, thats it. trying to locate one Frank allen 4106 |
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 29, 2005 - 11:54 pm: | |
Frank- Do you need a parts manual? |
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 30, 2005 - 12:57 am: | |
Frank: Dinosaur is for appliances; ignition boards. Was not aware that they made aftermarket boards for genset control. They are usually OEM items, at least for Onan and Kohler. |
Frank Allen
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 30, 2005 - 9:20 am: | |
John, i have a parts manuel but it does not show the part i need , some sets had a regtifier bridge which would be simple to go back to if i knew what the value and size of the resister is that goes with it. thanks for your help. Frank Allen 4105 2626 |
