pete hyser (4501pete)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 09, 2005 - 9:58 am: | |
Just took my rig out..huge wheelhop under power..at 45 to 80 flat land only..new shocks..steering box worked on..any ideas? pete |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 09, 2005 - 10:03 am: | |
front wheels...drive wheels...need more info |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 09, 2005 - 10:09 am: | |
inspect all tires...have seen bulge as big as a football on tire...make SURE brakes are released...will it roll after a slight bump of the clutch,bad u-joint,bad motor mount |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 09, 2005 - 11:08 am: | |
front wheel hop..tired are new..1200 miles on them i drove to north carolina and it was fine..happened on the way back automatic front end goes up pretty high.. |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 09, 2005 - 11:37 am: | |
are you talking about porpusing?(spelled wrong)if so,would say it's the shocks...or are the tires bounceing tires,does it do it when you slip it into neutral,at 60....even if you have an automatic...bump the throttle & see if it rolls...one brake could be hanging up... |
Stan
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 09, 2005 - 11:48 am: | |
When something occurs suddenly you have to suspect a component failure. In this case, the first suspect is a tire. Swap tires with drive or tag axle to see if it is a tire. Both a broken belt and an internal separation can only be seen by spinning the wheel at highway speed on a balancing machine. |
akrom
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 09, 2005 - 10:07 pm: | |
Sounds like the blounche filter is clogged and the by-pass has opened, allowing the wheels to bounce on alternating cycles. have the filter changed to one of the new titanioum/ceramic types and get back to us so we kow how it went. akrom better yet, check for a busted/split shock. |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 09, 2005 - 10:33 pm: | |
Check air pressures on tag axle and front end tires. Check tag axle air ride, too little pressure will remove load balancing support and allow the front to go too light. Cruisers need lots of support from the tags due to serious rear overhang behind the axle. Its a balancing act. I found that out when I had mine and removed the tires from the tags. The front was so light that the suspension would run all the way up with air applied. That's another reason that GM put duals on the tags. |
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 10, 2005 - 6:49 am: | |
tag was up..then down..and it didnt make any difference..i had a mechanic with me and he had no idea..he checked the shocks, tire preasure, steering box...ill have them check the blounche filter...? or whatever is sounds like..everyone has different names and i couldnt find that ove in the book.. it is not a dolphin..it is defenitly a hop and a rather bad one at that. my bed was when i hit that bump in NC that i did in fact break a shock but they said no... ill let you know...i have to be out of her ein a week or two.. pete |
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 10, 2005 - 3:25 pm: | |
Pete - i believe Akrom was pullin' your leg |
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 10, 2005 - 5:27 pm: | |
i knew that  |
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 10, 2005 - 5:52 pm: | |
We use to tell people to 'tighten your Jam Nuts' till we found out there actualy was such a thing |
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 10, 2005 - 6:11 pm: | |
lmao thats why i wear underware when i dance to bluegrass..i do the same thing |
Jim Bob
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 17, 2005 - 3:43 pm: | |
Jack each front wheel up. Position the valve stem at each "hour position" (10:00 , 2:00, 6:00 etc.)and release. If the wheel rotates back to a certain position you have an out of balance condition. In my 4104 it was due to unbalanced drums. (You can balance the tire/wheel forever and not catch this.) I found it by accident when I jacked up the bus to rotate tires. Went to the truck parts store & they said that balanced drums wouldn't make any difference due to the rotating mass. I insisted, paid $10 more per drum & the problem disappeared! Old drums had no balance weights, new drums have BIG chunks of steel welded to outside! |
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 17, 2005 - 4:15 pm: | |
I have had truck tire shops tell me that balancing duals would not help either. That is pure BS!. It can make a significant difference in wheels/tires and I am sure would make a difference if the dual drums were not balanced. Richard |
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 17, 2005 - 8:00 pm: | |
this happened in the middle of a trip..i drove 11 hours and it was perfect...on the way home...4 hrs into the ride home it started.. |
