carl l white
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 05, 2005 - 6:01 pm: | |
I am capping off my rear air beams because of a leak. Do you have to seal the air bags to the top and bottom plates and if you do what do you use? also do you have to put the air input into the top plate towards the engine or can you put them towards each other so it is easier to check for leaks? thanks carl |
Jim Ashworth (Jimnh)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 05, 2005 - 9:03 pm: | |
The bellows will seal themselves against the plates, no sealer is needed. The air inputs can go anywhichway that is convenient for you. Short and simple. Jim |
