Luke Bonagura (Lukeatuscoach)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 24, 2006 - 7:42 pm: | |
Hi Morgan & Folks: By now, you must realize there are no "Stupid" questions, but there certainly can be "Stupid" answers. Without seeing it, it sounds like your water pump might be the culprit. To be sure, it is a little bulbous guy mounted to the engine blower, with a "weep hole" on the bottom of it. Stick your little finger in that hole (WITH THE ENGINE SHUT OFF!!!!), and if it has "GREEN" on it, you have found the culprit. If you need one, you have the phone number. I Hope this HELPS! Happy & SAFE!! Bussin. to ALL. LUKE at US COACH |
