Made it to my parents in Sylva, NC. Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » January 2006 » Made it to my parents in Sylva, NC. « Previous Next »
captain ron (Captain_ron)
Posted on Sunday, January 29, 2006 - 10:52 pm:
no problems except for the marker and trailer lights started acting up again so I removed the last 2 marker bulbs on my trailer and that cured it. that fuse must be getting weaker. will fix that problem this week.
I came from Murfreesboro,Tn. to sylva, NC. on 64/74 went up and down 6 to 8% grades with no problems. temp. gauge didn't barely move. I'll start putting in interior this week. and if old bus sells I'll get a lot done
Bryce Gaston (Busted_knuckle)
Posted on Monday, January 30, 2006 - 1:41 pm:
Way to go Ron, glad to see things are going well with yer "new" coach except fer the trailer lights, but sounds as if you got a plan there! Good luck and have fun with it! Bryce aka Busted Knuckle
motorcoach1
Posted on Monday, January 30, 2006 - 2:45 pm:
ron i would concider putting LED lites on the trailer seems to have less current draw. just an idea.
Posted on Monday, January 30, 2006 - 3:17 pm:
Ron I'd go ahead and change that "weak" breaker and then go with LED's on the trailer! If you are running 12V trailer system! Bryce aka Busted Knuckle
Posted on Monday, January 30, 2006 - 3:53 pm:
Breakers do not normally get weak in the situation you have described. The connected load is just too high for the breaker rating. I also suggest you change all the trailer marker lights to LED'S to solve the problem.
Richard
