Ian, Weird Things Taking Place?? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » February 2006 » Ian, Weird Things Taking Place?? « Previous Next »
Posted on Thursday, February 09, 2006 - 11:37 pm:
Ian,
Often when I'm typing a small red box flashes at the bottom with an "X" at its left and says "Find"? Then everything I type shows up in the red box? It also makes all my words run together?
I am unable to make editing changes while typing like deleting or copying and pasting??
Is anyone else having this happen?
Posted on Thursday, February 09, 2006 - 11:50 pm:
Ya' gotta' insist on name brands, Gus. The damned generics can do that.
Phil Dumpster2
Posted on Friday, February 10, 2006 - 2:43 am:
Typing alt-e-f in mozilla brings up the 'find' box you are talking about.
Press ESC to make it go away.
Only you will be able to figure out how you are hitting that key combination in the first place.
Posted on Friday, February 10, 2006 - 8:44 am:
"Ctrl - f" also brings up the find box.
Richard
Posted on Friday, February 10, 2006 - 7:11 pm:
Gus,
It's never happened to me. I am on Netscape v7.2 and test the board on that and the significantly inferior IE v6 and the problem doesn't occur.
I can make what the others do, happen, but I fail to get a red box.
Anyone else ponder a thought here?
Posted on Saturday, February 11, 2006 - 12:34 am:
I try never to use the significantly inferior IE v6.
I get it while I'm typing a posting and also when I hit Ctl-C or Ctl-X..
The ESC sounds like the best solution, thanks to all for help. If I ever hit alt-e-f I wasn't aware of it. (I just copied and pasted the alt-e-f, I can't do either when the dreaded red box appears and the space bar quits working??) It only happens when I type all the way to the bottom of this "Add a Message" box.
Ian, I thought maybe you were trying to cut down the post lengths!! Just kidding!
Posted on Saturday, February 11, 2006 - 12:45 am:
Huh! I never had that happen!
But..... I use "the significantly inferior IE v6"!
Go figure? Conspiracy? Damn that Bill Gates!
