Damp rid Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » February 2006 » Damp rid « Previous Next »
motorcoach1
Posted on Wednesday, February 15, 2006 - 11:05 pm:
i've used this in the past the dehumidafier wasn't doing such a good job , how does it work for you folks.
motorcoach1
Posted on Wednesday, February 15, 2006 - 11:26 pm:
oh Ronthe busnut by the way if your running catalitic heaters this product will help pull the moister out of the air get it at home depot
motorcoach1
Posted on Wednesday, February 15, 2006 - 11:38 pm:
i ment captin ron lol
Sojourner (Jjimage)
Posted on Thursday, February 16, 2006 - 8:45 am:
No dehumidifier work when its room air temperature is below 65º F. It begins to freeze moisture on evaporator’s coil. Been there & learned.
All dehumidifier is a reverse air-conditioner.
So be sure to warm up interior to at least 70 F and then turn on dehumidifier.
Or you have more moisture coming then it can remove such as vent-less propane heater.
FWIW
Sojourn for Christ, Jerry
DMDave
Posted on Thursday, February 16, 2006 - 6:38 pm:
Mc1, people use it on boats up here in the NE during the winters. It slowly sucks up the water in the air and collects in the bottom of the container. It does work, and I always made sure they were put in the sinks or showers in case of spills.
Posted on Saturday, March 04, 2006 - 10:14 pm:
The de humidifier will work a lot better if you also run a box fan at the time to help circulate the air in the coach...The humidifier should provide enough heat in that size area to work ok unless it is below 45 degrees outside. If it keeps frosting up the coils, put it on a coffee pot timer and let it run 16 hours out of 24 to let the frost melt off the coils.
