calif bob
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 07, 2006 - 1:10 am: | |
WHER THE HECK IS THE OIL PRESSSURE SENDING UNIT ON AN 8v92? MY GAUGE QUIT AND TESTED IT WITH ANOTHER GAUGE WITH NO LUCK, CAN'T FING THE DARN SENDING UNIT. 1979 PREVOST |
Bryce Gaston (Busted_knuckle)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 07, 2006 - 1:20 am: | |
Bob theres no one place to point ya to as they are located in different places depending on application, I'd check the manual or call Prevost an ask where it should be! I've seen 'em on both sides, the front, and off a hose to a soleniod set-up, an I'm not real familiar with Prevost's anyway! |
Geoff (Geoff)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 07, 2006 - 8:43 am: | |
If you have a mechanical oil pressure gauge in the engine compartment see if the sending unit for the dash gauge is in the same place-- many buses use a manifold with a hose running to the engine to take the oil pressure reading, the sending unit could be there otherwise it is screwed into the side of the block next to the flywheel housing. --Geoff '82 RTS AZ |
califbob
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 07, 2006 - 11:20 pm: | |
Thanks guys. No mechnical gauge in the engine comp. It's an electric gauge. Guess I call some mechanic dude and ask. |
Jon W.
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 08, 2006 - 2:41 pm: | |
On my old one it was on the forward bulkhead, slightly right of center above the engine. On that assembly is the rear oil pressure gauge. |
califbob
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 08, 2006 - 11:11 pm: | |
FOUND IT! It was right in front of all the time. Jon W. you are right it's right wher you said it is. Now to figure out why it's notworking. Tomorrow I'm going to buy a mecanical gauge and put it along with a new sending unit. |
