Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 14, 2006 - 3:04 pm: | |
I am installing a camera system, pyrometer, and tachometer in an 89' MCI 102A3. I do not have the manual for this bus. Can someone tell me the front and rear panel terminal numbers for the alternator "R" terminal, Back up lights, and any spare wires from front panel to rear panel. Thanks, Jack |
C Fred
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 14, 2006 - 5:26 pm: | |
Jack I believe that the numbers are the same for all MCI, At least that is what I have found. check your Manual and see if they are . Fred |
Chuck Lott (Chuckmc8)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 14, 2006 - 7:41 pm: | |
Jack, I think this is what you need: Front Junction Box stud circuit # Color code gauge volt description 22 36C White 18 24 spare 29 63A Violet 14 - spare 41 815 Blue 16 12 B/Up Lamp Ground return 41 815 blue 18 12 B/U telltale 43 56 green 16 spare 76 36B White 18 24 spare 81 R1 Red-Black 18 24 Tachometer 81 Tach White-black 18 24 Tach signal from A Rear Junction Box 5 815 white 16 12 B/U lamps 48 F1 yellow 12 24 regulator 51 60 yellow 18 24 spare My book is 102D Series. I can send the book if you need it-or send more info- Hope this helps Chuck |
