Jack Tucci (Tuccitown)
Rating:  Votes: 1 (Vote!) | Posted on Thursday, March 30, 2006 - 7:01 pm: | |
Hi everybody, I am looking for a distributor in the Seattle area that carries the 2 Stroke 40wt oil. Anybody know of one? Thanks, Jack |
Tom Dessert (Mci5er)
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, March 30, 2006 - 7:18 pm: | |
I'm having the same problem finding DELO 100 40WT, here in Southern Oregon. I've checked NAPA, Shuck's and AutoZone chain stores. Plenty of DELO 400 around. The bigger truck stops seem to be the best bet. Tom |
Rob king
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, March 30, 2006 - 8:37 pm: | |
Hi Jack see if this link from google helps, leads you to email address and also an 1-800 number for product availibility, covers 400 and 100 http://www.chevrontexacodelo.com/en/deloworldwide/uscanadamexico/default.asp#delo100 hope this helps Rob 91 LeMirageXL Missouri |
Ear-8-Ky
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, March 30, 2006 - 9:29 pm: | |
Nappa has the Rotella T 40 wt. That is what I use. |
Arnold J Molloy (Ayjay)
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, March 30, 2006 - 9:33 pm: | |
Hi: Here's a listing of DD 2 cycle acceptable oils I copied from the RTS Forum: It might help having more than one choice of oil. Texaco "Ursa" Extra Duty Shell "Rotella"T Sunoco "DDC" Delo "100" Union 76 "Unitec HD" Castrol "Assuron" Citgo "Citi Guard Transit (Low ash) All are available in 30 and 40 weight AyJay |
Brian Elfert
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, March 30, 2006 - 10:43 pm: | |
Look for a lubrication distributor in your yellow pages. You will almost certainly have to buy by the case or more. When I needed an uncommon oil in the past (Before Walmart cerried it), I bought a case from a local distributor. A Farm and Fleet store might have 40 weight for tractors. Does Tractor Supply carry it? Brian Elfert |
Phil Dumpster2
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, March 30, 2006 - 10:52 pm: | |
Nelson Petroleum in Redmond has it in stock. It's about $6.50 a gallon. |
Leslie Robinson (Lesrmc9)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 31, 2006 - 12:04 am: | |
http://eolcs.api.org/FindBrandByServiceCategory.asp?ServiceCategory=CF-2 you will have to "play" with these to find you local distributors thanks to the following for the above website DetroitDiesel@yahoogroups.com TejasCoach Works also some excellant reading on why to 40 wt cf2 rating oil as opposed to multigrade oil http://tejascoach.com/ddcoil.html |
t gojenola
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 31, 2006 - 6:17 am: | |
Find the nearest Chevron distributor here and give them a call: http://www.chevron.com/products/prodserv/nafl/wheretobuy.shtm tg |
Dave Wilson
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 31, 2006 - 8:15 am: | |
I notice that no one mentioned Walmart for oil.Was a little hessitant at first but have used there 30 in the winter and 40 in the summer for several years now.Run original oil bath and do oil changes every second week costs about half of rotella t. I asked several people in the now before i changed . As long as its clean and slippry was the basic answer. |
Dallas Farnworth (Dal300)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 31, 2006 - 12:00 pm: | |
Dave, I have never seen 30 or 40wt in Walmart that was covered by API rating CF-2. I have seen Non detergent oil, and that's not what Detroits require. Why ruin a good $5,000 - $25,000 engine by saving a few cents on a gallon of oil? I don't use Rotella and I don't use Delo, but there are a lot of other brands out there that do conform to API CF-2. For more information on the reason Detroit Diesel requires API CF-2 check out this link and scroll down to 7SE270. http://www.detroitdiesel.com/support/on-highway/manuals/Lubricants_Fuels_Coolants/index.as p Godd Luck with whatever your Choice is. As Fred said, Do It Your Way. Dallas PD4103-1085 http://www.busconversionstuff.com |
Gary Carter
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 31, 2006 - 12:59 pm: | |
There should be a ton in the Seattle area. Just head to where the local fishing fleets hand out. 80% or greater fishing/shrimp boats are DD powered. |
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 31, 2006 - 9:37 pm: | |
Dave, I've used WM CF-2 oil since I got the 4104 but all my local store carries is 30W and can't order 40W, would like to find some 40W. It is about half the price of the other sources. |
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, April 01, 2006 - 5:32 am: | |
http://www.detroitdiesel.com/support/on-highway/manuals/Lubricants_Fuels_Coolants/A0010612 9E.pdf Page 29-30 of the .pdf, book pages 25-26 |
Michael Lewis (Puffbus)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, April 01, 2006 - 12:34 pm: | |
Seattle Truck Repair, at the N. end of the 1st Avenue S. Bridge (almost under)carries approved 40wt. Also have a good DD mechanic who previously worked for Grey Line and speaks MCI and DD. Nice guys and straight shooters in my experience. Michael |
Paul Klyczek
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 04, 2006 - 9:44 am: | |
I was new to this just last year and realy had a hard time with this DD motor oil thing. I Read everything I could find and then found it tough to find what was the "acceptable" oil. This is what I came up with,from NAPA You can buy their branded oil made buy ashland its called all fleet 40wt. It onlt comes in 5 gal containers but has the lowest ash content oil I could find. You can not get it in a valvoline counterpart as you can the rest of their oils. Bear in mind I know that branded oils do not always have the same add packages as the Valvoline counterpart.The difference in this case is this oil seems to be made just for this application. I own a competition engine shop and have a pretty good working knowlede of oils. This by no means makes me an expert but I do know how to keep an engine alive or kill it, and this looks like a good product. I ran it in my coach to minnesota to see my folks 1900 miles @ 2000rpm used about 2 quarts round trip. That was all the info I have, let me know what you all think. Paul and Dawn Klyczek PD4107-870 8V71 |
