walterwade
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, April 05, 2006 - 8:14 am: | |
my friend bought this bus and drove it home 6 months later ready to drive (yeah) here is first problem has air parking brake (with motor running) when you release brake air comes out of switch (did not do before) he ordered DA book but not here yet. I was wondering why it did this also havent seen bus yet because (he said) brake stop light stays on. and air pressure is very low. also anyone know the history on this bus if (this correct number) again thanks to all replies |
jlvickers
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, April 05, 2006 - 11:28 am: | |
Pd4106-354 From GMC to Virginia Stage Lines,Inc 1961 Virginia Stage Lines was a Trailways carrier. jlv |
Frank71
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, April 06, 2006 - 4:06 pm: | |
doughbt the book will do him any good as the 4106 did not come with a air operated parking brake and therfore it wont be in the book, it has to be a add on. Frank Allen 4106 |
Dallas Farnworth (Dal300)
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, April 06, 2006 - 6:46 pm: | |
Have him check the air governor. If the air is staying low and the switch leaks air when you try to release, that could be the problem. It could also have a cracked or broken line or air tank, but start with the governor first. Cost is about $20 for a replacement. Good luck. Dallas PD4103-1085 http://www.busconversionstuff.com/eventpage.htm |
walterwade
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, May 13, 2006 - 1:56 pm: | |
Dearest Frank, Apparently you missed the fact that the air operated parking break was factory and what has happened is the daiphram has busted in it so I need to find a replacement diaphram does anyone know where to get one? Thank you ever so much for any info on this part. |
