V730 oil cooler pressure Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » May 2006 » V730 oil cooler pressure « Previous Next »
Frank 4106
Posted on Saturday, May 13, 2006 - 8:01 am:
Hey Folks,
Does anyone know about how much pressure (psi) should be on the transmission fluid side of the oil cooler on a V730 trans????
Posted on Saturday, May 13, 2006 - 6:00 pm:
Don't know if this helps - The v730 maintenance manual says:
Main fluid pressre:
foward and neutral - 130 psi @ 600 rpms
reverse - 230-265 psi @ 1000 rpms
in direct (@700 engine rpms) - 150 psi
in reverse (@700 engine rpms) - 250 psi
modulator (clsed throttle) - 45-48 psi
lubrication 30 psi @ 2100 rpms
Pete RTS/Daytona
