Speedometer Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » May 2006 » Speedometer « Previous Next »
T. (Bluegrass)
Posted on Sunday, May 21, 2006 - 9:47 pm:
I have a Cummins engine with a Mt-653 Allison that I put In an eagle bus the speedometer don't work can someone tell me why and maybe if theirs a fix for It.
thank you
Tony
T. (Bluegrass)
Posted on Sunday, May 21, 2006 - 9:57 pm:
almost forgot the Allison come out of a ford 8000
and the eagle has VDO gauges
mel 4104
Posted on Monday, May 22, 2006 - 3:15 pm:
you will need the gauge to match the sender, it is rare that they match from different sources. however if the back of the gauge has switches on it the you might be able to set it to the sender or very close. and to keep the gauge you will have to find a proper sender as they come in different ratios.
