Question for Fast Fred Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » June 2006 » Question for Fast Fred « Previous Next »
t gojenola
Posted on Monday, May 29, 2006 - 4:50 pm:
In an ancient thread in the archives, you mentioned using a "sight glass" in the fuel line exiting an 8V71 primary fuel filter to detect the presence of air. Great idea that I would like to use. Problem is finding the right sight glass - specifically one with compatible pipe threads. Just wondering if you can point me in the right direction - my sources here in Anchorage are very limited. Help appreciated.
tg
frank-id
Posted on Monday, May 29, 2006 - 6:29 pm:
Hey Tony, The sight glass that I founde came from HVAC suppliers. These parts can be found with may methods of attachment. My last glas had pipe threads which were adapted to compression fittings. The glass units I installed were installed horizonally. Frank
Posted on Tuesday, May 30, 2006 - 5:36 am:
Frank is right , the folks that supply parts to fridge repair folks will have Armored sight glasses with flair (M or F ) fittings that are a snap to install.
Built for 200psi so no hassle in the fuel line.
johnwood
Posted on Wednesday, May 31, 2006 - 7:41 pm:
might try one made for ammonia refrigeration..... they use steel parts for ammonia and lotsa ips pipe threads.
jw
t gojenola
Posted on Thursday, June 01, 2006 - 1:19 am:
Thanks for the replies. I have given up on the local HVAC folks and their propensity to not cooperate with do-it-yourself individuals such as myself. Web searching reveals a lot of possibilities, along with their respective limitations, including maximum temperature. But I think I have settled on a steel-bodied unit carried by McMaster-Carr that will work. I can adapt the fittings.
http://www.mcmaster.com/catalog/112/PDFPrinterFriendly/0494.PDF
tg
