12 v slide controller ? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » June 2006 » 12 v slide controller ? « Previous Next »
Ken Turner (Pipesusmc)
Posted on Saturday, June 17, 2006 - 4:55 pm:
Where can I find a slide out controller with auto stop at each end, for an electric 12 volt slideout? The one I have now is kind of wimpy!
When I disconnect motor wires from the wimp and go directly to the same battery, it has much more oomph
Thanks.......... Ken
Jack Gregg (Jackinkc)
Posted on Sunday, June 18, 2006 - 1:31 pm:
Dr Dave (hartley@rvbus.net) used to have some of these, I thought.
Jack
(Message edited by JackInKC on June 18, 2006)
truthhunter@shaw.ca
Posted on Sunday, June 18, 2006 - 4:38 pm:
IF your mechanism work well at one time, maybe a voltage drop test (more than . 1 volts per conections) would indicate were the resistance had built up (burning contacts, corroded contacts) and you may repair the components you have with a simple cleaning/filling.
If your manufacture can not get you OEM replacements you might try these side components manufactures, some don't retail there products but you could ask them kindly to refer you to someone that does.
http://www.validmanufacturing.com/ or http://www.kwikee.com/Aslides.html or http://www.barkermfg.com/product_pages/slide_out_systems.html
