Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 24, 2006 - 2:46 pm: | |
Will probably have to call Prevost Jacksonville monday - But - Was checking my Group 31's before hopefully heading out - when I pulled the battery slide out it only came half way - one of the side slides appears to be hung up - the battery compartment is completely enclosed by bulkhead so I can't see very far back - it slides fine then just hangs up on one side - Any ideas of what it is or how I can get in the compartment? - Thanks in advance - Niles |
H3-40
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 24, 2006 - 5:27 pm: | |
Hey Niles make sure you check the cables and see if they aren't holding it from comingout! Mine did that once and I had to tie wrap them to each other so they wouldn't rise up once they went in! Ace |
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 24, 2006 - 8:06 pm: | |
If it's not the cables, then..... One can of "Power Blaster" (walmart, auto stores, etc) and shoot the stream -into- the slider mechanism at each side. You'd want to totally saturate the slider and the wheels inside the slider. Work the slider in and out, and it should work free. |
Randy Davidson
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 24, 2006 - 10:09 pm: | |
I'll predict that it's a cable that got loose from a cable tie. Once it hangs down and bends it gets a memory for that position. You might try a wooden stick or dowel to reach in and lift as you slide the tray out. Once out, as Ace says, re-cable tie to the others. Let us know what you find out. Randy |
