Towing question Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » July 2006 » Towing question « Previous Next »
Larry & Lynne Dixon (Larry_d)
Posted From: 216.228.194.212
Posted on Thursday, July 06, 2006 - 1:08 pm:
Well back again.
I heard somewhere that the towing connection on the coach should be higher than the towbar connection on the toad. Is this correct.
The 4905 is quite low and takes about a 5" rise in the ball. Thanks again for all the help everyone has been
4905 Larry
Jerry @NC
Posted From: 68.67.105.79
Posted on Thursday, July 06, 2006 - 1:15 pm:
All should be the same heigth.
Posted From: 67.141.147.40
Posted on Thursday, July 06, 2006 - 4:02 pm:
According to Blue OX http://www.blueox.us/instruction/towingphysics101.htm
the receiver should be at the same level as the car. It can be up 4" higher on the coach but never lower.
There is a good explanation in the link above.
Len Silva
Posted From: 207.30.189.34
Posted on Thursday, July 06, 2006 - 4:39 pm:
Roadmaster says level is best and base-plate pivot pins on car should be no more than 3" higher or 4" lower than the center-line of the receiver on their coach mounted tow bar. Although they do not mention toad mounted tow bars in the service bulletin, I would shoot for level. Not worth the risk when you consider the possibilities that can occur should the toad separate from the coach.
jack
Posted on Thursday, July 06, 2006 - 5:44 pm:
Thank you very much Jerry, Len and Jack, Your posts were needed I have towed lots of miles but did not have such a low towing vehicle. The 4905 is quite low but I have several recievers. It is sure great to have so much help THANKS
4905 Larry.
