Bob Greenwood Posted From: 63.233.5.37
Rating: Votes: 1 (Vote!) | Posted on Friday, July 07, 2006 - 2:57 pm: | |
I have an older duo-therm & the compressor quit comeing on. SO, I thought I would replace the start capacitor and the run capasitor,well the little one came right out,but it looks like the red one has been installed at the factory & had a rolled/crimped edge where I can't get it out,QUESTION: can I just hang a replacement on the side? |
Arthur J Griffith
Posted From: 72.236.102.207
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 08, 2006 - 1:08 pm: | |
Yes: Secure it well and you should be OK. You don't want it coming off and shorting out. You can strap it anywhere close by. Be sure all the wireing is disconnected from the old cap and properly installed on the new one. Be sure the new cap. is rated the same. GOOD LUCK ARTHUR |
Brent Coursey (Busboy)
Posted From: 65.39.118.10
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 08, 2006 - 1:42 pm: | |
I have a duo-therm, one of 3 on the bus and one of them while running acts like the compressor does not want to start...the lights dim in the coach and it makes a sound the compressor does not want to come on. But it is cooling and I can tell the compressor does come on normal sometime. What could be the problem? Happy Trail, Brent |
Bob Greenwood Posted From: 63.233.6.73
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 08, 2006 - 3:40 pm: | |
sounds like the same thing Brent, I'm definitely not an A/C person.BUT, this is what I've found out so far,the start capacitor gives the motor an extra boost',then the run capacitor kicks in, when the lights dim ,that means that one of them is going out & it can burn out the other one,the silly thing I did, I 'thought' I was changeing out the start/run capacitors & I was in the WRONG area., I changed the thermal overload on top of the dryer,just went in & talked to a Duo-therm guy & he sez the capacitors are under a metal cover ,I still haven't gottten up on the roof to find them |
Arthur J. Griffith
Unregistered guest Posted From: 72.236.102.177
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 09, 2006 - 11:24 am: | |
BRENT- Bob is correct in thinking that the start capacitor is probably getting weak or has gone bad. A weak or bad cap. can eventually toast the compressor and also the fan motors. I usually change out both start and run caps at the same time even though only one is bad. That has been standard practice for me for many many years. Caps are fairley cheap in comparison to the labor it takes to replace one maybee next month. Your compressor and fan motor will LOVE YOU for it and maybe deside to stay around for a long time Good Luck ARTHUR |
Bob Greenwood Unregistered guest Posted From: 63.233.105.149
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, July 11, 2006 - 12:03 pm: | |
I found the problem,whoever origionaly wired it,pinched a 110 wire going to the thermostat& it burned in half |
