Weight of an Eagle Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » July 2006 » Weight of an Eagle « Previous Next »
Gene Lewis (Genelewis)
Username: Genelewis
Post Number: 44
Posted From: 69.132.159.82
Posted on Saturday, July 15, 2006 - 12:11 am:
We are moving and I will need to store my 05 Eagle for a few weeks till we can get a new driveway installed. I have a temporary location in mind but the question of how much it weighs.
Can anyone tell me what a typicwl -5 Eagle weighs?
Thanks in advance.
Enjoying the journey in NC,
Gene
Bob Greenwood
Unregistered guest
Posted From: 65.150.47.23
Posted on Saturday, July 15, 2006 - 1:02 am:
27,000
Username: Drdave
Post Number: 655
Posted From: 67.78.176.54
Posted on Sunday, July 16, 2006 - 9:15 pm:
Worst Case is use the max tire ratings and add them all together. I use that when figuring how much base to put down to park on. So if each rating is 7,000 lbs @120 psi, Times the number of tires on the ground. Like an RTS 2-tires on front = 14,000 lbs. 4-tires on back 28,000 lbs. so add the front to the back for approximate worst case maximum weight. aka 42,000 lbs. The GVW label says 36,900 lbs and in reality empty would be more like 23,000 lbs.
An Eagle probably weighs more so the numbers might be a lot different. Maybe more maybe less...
The reason that I brought this up. That we have lots of soft ground and sand. I have to really be careful when putting down a hard base to drive across. Clay on top of sand is still sand and will sink. Gravel just pushes down because sand passes through the spaces. I use about 6 inches of Ground up Concrete and water it in good before parking on it. I don't get buried in the yard anymore either. 4 to 6 inches of concrete works too!
Bob cox
Unregistered guest
Posted From: 75.14.214.104
Posted on Thursday, July 20, 2006 - 10:39 pm:
Jean Great looking Eagle!!
As for the weight last check on my Eagle was this 9400lbs front ax the rear came in at 24000 with the over all weoght near 34,000 Lbs. fully stocked!!
Username: Drivingmisslazy
Post Number: 1635
Posted From: 141.153.58.2
Posted on Friday, July 21, 2006 - 8:12 am:
MY Eagle 10 was 42,000 fully converted and loaded to the gills.
Richard
(Message edited by drivingmisslazy on July 21, 2006)
Username: John_mc9
Post Number: 4
Posted From: 66.217.105.49
Posted on Monday, July 24, 2006 - 12:46 am:
11 tons empty, was the standard reply back in the 60s.
Tom Hamrick (Tomhamrick)
Username: Tomhamrick
Post Number: 63
Posted From: 167.83.101.23
Posted on Wednesday, July 26, 2006 - 3:02 pm:
Gene,
Where ya moving to???
Tom Hamrick
