Mc9 radiators Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » August 2006 » Mc9 radiators « Previous Next »
Dan Benjamin
Unregistered guest
Posted From: 66.163.141.72
Posted on Tuesday, July 18, 2006 - 1:50 pm:
anyone know where to find cores or complete radiators for mc9. Diesel radiator said they had neither which surprised me after reading others had purchased from them. MCI has both cores and radiators but are more than I want to spend.
Burgermeister
Unregistered guest
Posted From: 64.142.42.176
Posted on Tuesday, July 18, 2006 - 3:44 pm:
Which engine, 6V92 or 8V92?
Where do they need to be delivered?
dan
Unregistered guest
Posted From: 66.163.141.252
Posted on Tuesday, July 18, 2006 - 5:42 pm:
1980 mc9 with 8v71 engine without turbo. the old radiators are borg-warrener part nu. 6r-138. I am located in north central North Dakota.
Burgermeister
Unregistered guest
Posted on Tuesday, July 18, 2006 - 6:53 pm:
What are your overall intentions with the bus?
Do you plan to remain with the same engine, upgrade or repower?
I have no formal posture, one way or the other.
(but if pressed, would opine that there's a huge amount of ego-driven desire somehow associated with the need to run to the crest of "Rockytop" at 65+ MPH) Those who dare should check out the Caterpillar site for the RV Performance page.
Most either upgrade or aspire to do so. If you aspire to something better or bigger, I'd do the radiators now, as it's false economy otherwise.
Ed Roelle (Ed_roelle)
Username: Ed_roelle
Post Number: 21
Posted From: 68.85.142.19
Posted on Wednesday, July 19, 2006 - 8:01 am:
I installed brand new replacement radiators and seals in my MCI 8 (8V71) from Diesel Radiator in Chicago. In hot weather, in the mountains, I would have to stop to cool down with those new radiators.
When I repowered with an 8V71T, there was no question in my mind that I should change to the "102" radiators. I think they were 6K-1-5, $1900 from Diesel Radiator. Pulley diameter and fan size is important too.
Ed Roelle
Flint, MI
Unregistered guest
Posted on Wednesday, July 19, 2006 - 11:19 am:
Ed, No argument with your observations. I agree totally with larger radiators. Gumpydog has a nice how-to chapter on up-sizing MCI radiators. However, with a standard 8V71, the replacement radiators should have easily handled the heat load. I suspect you had a aeration problem or maybe a head gasket leak, or?? in the 8V71, leading to the problem you observed. Was the installation or hookup of the replacement radiators any different from the original, factory setup? Re-routing a line or changing a fitting can have a marked effect.
marcschlabach
Unregistered guest
Posted From: 70.58.189.102
Posted on Wednesday, July 19, 2006 - 8:19 pm:
Hi Dan, Give me a call sometime. Right now we are in the "rockies". Before we left I put spray nozzles on my radiators, and I'm sure glad I did. With a selanoid valve and a switch at the drivers seat it's real easy to cool her down. Hope you find your radiators. Marc
Dan
Unregistered guest
Posted From: 66.163.141.63
Posted on Wednesday, July 19, 2006 - 8:30 pm:
Thanks for all the help. I'm ordering the 6k-1-5 from Diesl Radiator.The "102" radiators are actually less through them then the original radiator through MCI. Guess I'll find out what it takes to get them installed. From what I remember seeing somewhere It takes a bit of fabrication to make them fit. Where do I find info from Gumpydog?
Dan
Unregistered guest
Posted on Wednesday, July 19, 2006 - 8:41 pm:
Hi Marc! After posting my note I saw yours so thought I'd respond. We were in Colorado just recently for a family reunion. Spent a few days at a retreat west of Loveland and then went down to Colorado Springs and visited Focus on the Family. Have a wonderful trip.Dan
Username: Ed_roelle
Post Number: 22
Posted on Thursday, July 20, 2006 - 9:05 am:
Here is Craig's site (Gumpydog). Excellent info.
http://www.gumpydog.com/bus/MC9_WIP/Mechanical/Radiators_And_Blowers/radiators_and_blowers .htm
Marc - when I had temperature problems, everything was stock design and sealed well. I did have N65 injectors and later found that it did not have advanced timing - which may make some difference. Also, it was over 100 degrees and we were in the Rockies pulling a heavy car. It was miserable.
My point - IF you are changing radiators, do it right once-and-for-all by going with the largest radiator, large fans, and small pulley.
Ed
Mark Scott
Unregistered guest
Posted From: 12.165.160.180
Posted on Friday, July 21, 2006 - 4:30 pm:
Dan, I have a set of used radiators in my shop. I removed them from my MCI 102A3, they were designed for a 6V92T. I have a 8V92T, they were slightly undersized. They look great and I had no problems with them. Contact me thru this board if you are interested. I have them sitting on a pallet. I am in Ohio
Chuck Lott (Chuckmc8)
Username: Chuckmc8
Post Number: 172
Posted From: 68.223.21.175
Posted on Tuesday, July 25, 2006 - 9:19 am:
Mark S, I am interested in your 102 Radiators....How can I get in touch with you? 14bama@belsouth.net
Mark Scott
Unregistered guest
Posted on Monday, July 31, 2006 - 9:36 am:
Chuck, your e-mail address comes back undeliverable. Do you have a new e-mail? Let me know thru this forum. Mark
DrEd
Unregistered guest
Posted From: 72.65.143.197
Posted on Saturday, August 05, 2006 - 6:24 am:
I have two complete radiators I removed from my 102A3. One is in good condition the other in fair condition. Neither one had begun to leak yet and had just completed a trip through the eastern mountains of PA, NY, WV and NC, also, a trip west to Nevada using the radiators was successful with no heating problems. The A3 had two sizes of radiators and these are the smaller ones. Will sell if price can be determined. Thanks. DrEd.
