12 volt alternator charging house ba... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » August 2006 » 12 volt alternator charging house batteries « Previous Next »
Mich Campbell
Unregistered guest
Posted From: 206.172.191.129
Posted on Tuesday, August 01, 2006 - 3:47 pm:
Would any of you gentlemen/ladies have any idea how I can get this set up to work. I run a belt off the now removed AC pulley to a 12 volt 140amp alternator as per instructions from a post I got off this board some time ago. I cannot get it to start charging, any info would be great. Thanks in advance
Bob greenwood (Bob_greenwood)
Username: Bob_greenwood
Post Number: 38
Posted From: 63.233.42.145
Posted on Wednesday, August 02, 2006 - 10:36 pm:
I'd be glad to help,did you get a delco remey with the regulator built in it??do you have the cable hooked to your house batteries?? is it a 'one wire' alternator ?
Username: Cowlitzcoach
Post Number: 117
Posted From: 206.163.13.34
Posted on Wednesday, August 02, 2006 - 10:59 pm:
Is it turning the correct direction?
Post Number: 39
Posted on Wednesday, August 02, 2006 - 11:15 pm:
it will charge either direction,it will cool better with it turning the correct direction
Ross Carlisle (Rrc62)
Username: Rrc62
Post Number: 135
Posted From: 67.33.46.218
The Bosch one-wire I installed will charge in either direction. Pretty sue that's true of any alternator. I think the only difference is the cooling fan. Some are internal, some are external and some are bi-directional....like the Bosch.
The Bosch has a delay before it starts charging and it needs to see a certain RPM, although I don't know what that RPM is. If it's turning too slow, it will not turn on and start charging. May go without saying, but it also needs to be hooked to a battery. I actually know a guy that tried to connect an alternator output directly to a 12V buss bar with no battery....Then when it didn't work he took it back claiming it was bad.
Username: Gusc
Post Number: 151
Posted From: 66.175.159.99
Posted on Friday, August 04, 2006 - 3:53 pm:
Ross is correct, those one wire alternators are a pain because of the high rpm exciter requirement. On a slow turning diesel you are far better off with a regular alt with a built in reg, very simple to install.
If I were going to use one to charge house batteries only I would use one of the small GM ones from a car, they are cheap and reliable. There is a certain way to hook them up but it isn't difficult.
(Message edited by gusc on August 04, 2006)
