Accelorator pedal lock Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » August 2006 » Accelorator pedal lock « Previous Next »
Phil Hendrix (Phil9tx)
Username: Phil9tx
Post Number: 1
Posted From: 69.30.187.189
Posted on Tuesday, August 29, 2006 - 7:32 pm:
A strange thing happened upon returning home yesterday in our 84 MCI 9. I pulled into the driveway and had to backup and reposition when I did this the accel. pedal locked up in drive but, not in reverse. I got out and unhooked the car and when I got back in and put in forward it worked.
When we left Waco earlier in the day I noticed that the airlock door mechanism would release and go on intermittently. Then, when I applied the brakes it would go off. I drained both wet tanks and the rear air valve. My compressor maintains 120 lbs. The little red ball air door lock is not functioning. Any ideas?
Username: Dnick85
Post Number: 46
Posted From: 66.174.79.232
Posted on Wednesday, August 30, 2006 - 6:59 am:
Phil,
That is a safty. It's a air valve under the peddal that prevents you from accelerating if the bag door valve is released.
I removed the lock from my peddal.
Nick-
Username: Phil9tx
Post Number: 2
Posted on Thursday, August 31, 2006 - 3:29 am:
Where do U find this safety valve?
Username: Dnick85
Post Number: 50
Posted From: 66.174.92.164
Posted on Thursday, August 31, 2006 - 7:22 am:
Phil,
You will find it by climbing into your spare tire compartment and looking up at the throttle cable. My selonoid was at the floor flange.
Yours might be behind your peddle. There will be an air line connected to it. After removing the valve you will have to cap off the air line.
Good luck
Nick-
