Nick Morris (Nick3751)
Registered Member Username: Nick3751
Post Number: 387 Registered: 1-2004 Posted From: 63.121.247.31
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 29, 2006 - 9:44 pm: | |
I don't know if they never had any or if the guy before me did away with 'em when he hose clamped the simi turn signal switch to the colum but I need to rewire the flashers. What kind of relays or whatever do I need to make both turn signals flash when they're supposed to and not when they're not? |
Tim Hoskinson (Tdh37514151)
Post Number: 181 Registered: 9-2004 Posted From: 4.252.65.233
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 30, 2006 - 9:49 pm: | |
Hi Nick if you are reffering to emergency flashers then no they did not have them. Only direction signals that were controlled by a lever on the right hand side of the steering columb. Remember we are having our antique truck and equipment show this weekend and would love to have your bus on display. Tim |
jl vickers Unregistered guest Posted From: 71.52.82.62
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 30, 2006 - 4:47 pm: | |
On the PD3751 the turn siginal lever type switch was on the right side of the steering collumn down below the gear shift lever. Lever up left hand turn siginal Lever down right hand turn siginal Tell tale red light flashes on and off when turn siginal is in operation located below switch. The directional siginal flasher is located in the buzzer and relay panel assembly. This above information is from the PD3751 maintenance manual X-4711. This is all of the information I have on the PD3751 silverside |
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 30, 2006 - 4:54 pm: | |
PD3751-272 history from GMC to Atlantic Greyhound Lines Charlston,WV. |
bbowden Unregistered guest Posted From: 71.53.232.150
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 05, 2006 - 2:03 pm: | |
our 3751 has them. Top left corner of the instrument panel. |
Post Number: 388 Registered: 1-2004 Posted From: 63.121.247.31
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 06, 2006 - 7:19 am: | |
Ok guys mine has been rewired at least twice. Once I did it but once it was done before me. So now there is no relay no switch no nothing so what do I need to put flashers back on it? |
Post Number: 389 Registered: 1-2004 Posted From: 63.121.247.31
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 06, 2006 - 7:21 am: | |
