Remove exhaust pipe from turbo? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » September 2006 » Remove exhaust pipe from turbo? « Previous Next »
C. Ray Powell (Raypowell)
Username: Raypowell
Post Number: 85
Posted From: 70.223.70.124
Posted on Tuesday, September 05, 2006 - 10:54 pm:
6V92 with the exhaust pipe stuck to the turbo.
How do I seperate them?
Thanks
C Ray
frank-id
Unregistered guest
Posted From: 67.136.152.216
Posted on Tuesday, September 05, 2006 - 11:47 pm:
A terrific product named PB Blaster will free about anything. Product sold at wallmart. Great product. Spray liberally at jointm wait an hour and tap exhaust with hammer or block of wood. Frank
JR Lynch (Njt5047)
Username: Njt5047
Post Number: 47
Posted From: 69.132.238.127
Posted on Wednesday, September 06, 2006 - 8:25 am:
Have you attempted to remove the outer "sleeve?" That should be a loose (relatively) fit. There are two clamps with a link between them...remove the link and the exhaust pipe, with the large "bell" should fall off...if we are talking about the exhaust pipe, loosen the muffler end of the pipe and move it around...it's on sealing rings that will loosen up.
Are you removing the exhaust pipe or the turbo inlet pipes? Post a pix of what's stuck?
PB Blaster is great stuff. Highly recommended.
JR
(Message edited by njt5047 on September 06, 2006)
Username: Raypowell
Post Number: 86
Posted From: 70.223.68.160
Posted on Wednesday, September 06, 2006 - 10:41 pm:
I am removing the exhaust pipe from the turbo.
I removed the clamp and using a block of wood & hammer nothing happened. Did not want to strike very hard.
Thanks
C Ray
Bob greenwood (Bob_greenwood)
Username: Bob_greenwood
Post Number: 125
Posted From: 65.150.45.39
Posted on Wednesday, September 06, 2006 - 11:14 pm:
take the other end of the pipe loose also
