Differences between 4104 and VL-100 Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » September 2006 » Differences between 4104 and VL-100 « Previous Next »
Doug J 4104 (Doug_j)
Username: Doug_j
Post Number: 7
Posted From: 207.199.206.169
Posted on Wednesday, September 06, 2006 - 11:05 am:
Wanted you guys input on the differences, pros/cons, etc... between my '59 4104 and a '59 flxible VL-100. Thanks
Username: Rjlong
Post Number: 1014
Posted From: 71.195.113.23
Posted on Wednesday, September 06, 2006 - 6:58 pm:
Doug J -
Both are 35' coaches, GM has the V-drive, Flx is a T-drive.
GM has a flat floor, Flx has a dropped center aisle.
GM is air suspension, Flx has Torsilastic (Same as Eagle).
VL-100 continued production virtually unchanged for many years by Dina in Mexico, so parts may still be available, altho it would take some digging to find them.
GM is basically all-aluminum, Flx used steel tubing, so may have hidden rust issues - especially around the Torsilastic mounting points.
VL-100's are way cool 'cause there's so few of them, with a look and ride all their own.
HTH. . .
Bob greenwood (Bob_greenwood)
Username: Bob_greenwood
Post Number: 126
Posted From: 65.150.45.39
Posted on Wednesday, September 06, 2006 - 11:21 pm:
the VL-100 is LOTS better looking,it has a bigger engine ,will get about 8 mpg, the 4104 has a smaller engine & will get about 10 or 11 mpg
DMDave
Unregistered guest
Posted From: 71.125.9.62
Posted on Thursday, September 07, 2006 - 6:10 am:
The drop center Isle can be limiting on your layout. It is a drawback on our coach.
