Jerome Price (Sundancekid45)
Registered Member Username: Sundancekid45
Post Number: 1 Registered: 8-2006 Posted From: 207.155.103.235
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, September 10, 2006 - 6:16 pm: | |
I’ve been reading post for about 3 months I’m going to pick up our 1968 40’ Eagle 01 in a couple of weeks it has been a couch for the past 30 years I want to totally rebuild it the first thing I’m going to do is raise the roof and my question is once I remove the old windows and replace ones were I want them when putting on the fiberglass siding and front and rear caps what is the pest way to fasten them in place I don’t want to see any rivets as I have seen on other buses. Thanks for any info. |
Craig (Ceieio)
Registered Member Username: Ceieio
Post Number: 262 Registered: 12-2004 Posted From: 206.212.230.165
Rating:  Votes: 1 (Vote!) | Posted on Sunday, September 10, 2006 - 7:01 pm: | |
Jerome, Fiberglass + No Rivets = Sikaflex 252 Call International Bus Parts and they can set you up with what you need. I used it on my metal siding and liked it. Craig - MC7 Oregon |
Post Number: 305 Registered: 10-2003 Posted From: 69.162.3.30
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, September 10, 2006 - 8:39 pm: | |
I hope you have studied the posts about the rust issues with older coaches and deal with that first.Otherwise, we are looking forward to your progress. |
Post Number: 185 Registered: 2-2004 Posted From: 66.90.197.232
Rating:  Votes: 1 (Vote!) | Posted on Sunday, September 10, 2006 - 8:39 pm: | |
Jerome, I bought fiberglass from R&M and their caps too. I riveted the top of the sheet at the drip rail, under the roof skin and at the bottom (in the belt line). I covered the belt with a trim piece. The middle was glued with a urethane caulk (Savogran NP-1) Sikaflex is the same stuff. I did this in 2000 and have had no problems. The caps are riveted around the edges. All other places in the middle are glued. The rear cap goes under the roof skin. The front goes over the roof skin. Warning--do not try to make a bondo butt splice where the caps meet the fiberglass siding ends. It will crack no matter what you do. Just glue a trim piece and let it float. David |
Connel (Connel)
Registered Member Username: Connel
Post Number: 28 Registered: 10-2004 Posted From: 70.248.214.151
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, September 10, 2006 - 10:28 pm: | |
Craig, John & David are all correct. But, don't let a little RUST scare you. Been There Done That and burned many holes in the T-shirt. Connel |
Post Number: 2 Registered: 8-2006 Posted From: 207.155.103.235
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 11, 2006 - 10:39 am: | |
Thanks, you all have been a big help. This will be our first bus, but we have been in a 5th wheel trailer for 3 years. |
