bernie newcomb (Newk)
Registered Member Username: Newk
Post Number: 2 Registered: 9-2006 Posted From: 64.12.116.138
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 13, 2006 - 6:15 pm: | |
i have the origanalwindows in my 4104. they have started to leak. i caulked around the windows. the leak seems to be below the window, but i can't find it-does anyone have any ideas thanks bernie |
Jerry Liebler (Jerry_liebler)
Post Number: 231 Registered: 3-2005 Posted From: 71.31.7.92
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 14, 2006 - 9:49 am: | |
Bernie, My windows started to leak after hard rains after I replaced the outside rubber gasket. What was happening is water was leaking through the pins that hold the windows at the bottom. Basically the outside needs drain channels through the outer gasket. Regards Jerry 4107 |
Harwood Burritt (Captwoody)
Registered Member Username: Captwoody
Post Number: 2 Registered: 9-2006 Posted From: 151.196.119.98
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 22, 2006 - 6:27 pm: | |
There is a marine product called gluvit. It's a two part system about the consistency of heavy paint excellent leak repair, seeks out the leak and seals it. I use that for stubborn leaks before I apply any caulking or bedding compound. |
Erston Reisch (Erston)
Registered Member Username: Erston
Post Number: 1 Registered: 10-2006 Posted From: 64.156.190.196
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 18, 2006 - 5:08 pm: | |
Where can you buy gaskets for 4104 windows? Are they very expenisve? ~ Erston (delurking) |
