Tranny and power steering fluid Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » September 2006 » Tranny and power steering fluid « Previous Next »
mich campbell
Unregistered guest
Posted From: 216.209.112.141
Posted on Monday, September 18, 2006 - 8:42 pm:
I have a MC8 with 4 speed manual trans, and 8V71
engine, could any of you out there tell me what type of fluids are used in the tranny, and power steering. Thanks to all
Bob greenwood (Bob_greenwood)
Username: Bob_greenwood
Post Number: 155
Posted From: 4.227.116.124
Posted on Wednesday, September 20, 2006 - 8:50 am:
I can tell you that my Eagle 4 speed manual trans. uses 40 wt. motor oil & I think the power steering should use the same, this is in my Eagle book, this comes up often, & everybody wants to argue about it,the only thing that uses 90 wt is the rear end
JR Lynch (Njt5047)
Username: Njt5047
Post Number: 66
Posted From: 69.132.238.127
Posted on Wednesday, September 20, 2006 - 9:32 pm:
The power steering thing comes up frequently.
Be sure and check the color of your PS fluid.
If it's red...it's Dexron auto trans fluid (GM automotive).
If it's brown, it's motor oil..40wt.
The two fluids don't mix. You'll want to be certain of what you have before adding fluids. The top comes off the res easily..if you cannot see the fluid in the res window, take off the top of the res and sample your fluid.
Both fluids are used, and both work well...just don't mix.
JR
Post Number: 159
Posted From: 4.227.115.196
Posted on Wednesday, September 20, 2006 - 10:13 pm:
is this a Richard Pryor thing,do they blow-up.they mix just fine,
Username: Gusc
Post Number: 190
Posted From: 63.97.117.14
Posted on Wednesday, September 20, 2006 - 11:25 pm:
Mich,
You need to get the absolutely correct info on the 4 sp. Older GMs with Spicer 4 sp like my 4104 use 50W mineral oil because they have an oil pump. Lots of people don't believe this but I have some heavy '50s GM trucks that have the same trans and also use 50W. These trans do not like 90W and it would probably be a disaster in very cold weather.
I have no idea what 4 sp your MC8 has but you need to make sure.
Post Number: 160
Posted From: 4.227.114.164
Posted on Thursday, September 21, 2006 - 5:10 am:
nobody said 90w
Username: John_mc9
Post Number: 106
Posted From: 66.217.106.206
Posted on Thursday, September 21, 2006 - 10:13 pm:
There's a page from the MCI manual here, providing that info!
Username: Gusc
Post Number: 191
Posted From: 63.97.117.33
Posted on Thursday, September 21, 2006 - 10:36 pm:
I don't think I said that anyone said 90W.
