dave babb
Unregistered guest Posted From: 150.193.16.6
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 02, 2006 - 3:38 pm: | |
Can windows from a van conversion be used on a bus conversion? |
Brian Elfert (Belfert)
Post Number: 16 Registered: 7-2006 Posted From: 132.148.80.215
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 03, 2006 - 12:23 pm: | |
I'm not sure about current van models, but vans usually have curved sides so the conversion windows are curved to fit the sides. Windows designed for flat sides should work if they can be mounted. I never noticed if conversion van windows are mounted in a molding or with a flange ring. I am guessing a molding which would be difficult to use. Brian Elfert |
Cliff (Floridacracker)
Post Number: 300 Registered: 7-2004 Posted From: 65.33.146.203
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 04, 2006 - 1:00 am: | |
Dave, Van windows have a slight curve to them. I have four NOS conversion windows for Ford vans. If you can't physically get ahold of the windows I would make a template against the side of a van made of cardboard and check the curvature. The windows I have the PO thought they would work, but too much curve for my straight sides. Best of luck Cliff |
JJ Woden Unregistered guest Posted From: 65.19.246.49
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, October 05, 2006 - 2:57 pm: | |
You might sell them to an RTS owner/converter. They have nice curved sides. (The RTS I mean ... not the owners) JJ |
