TOM SHALLOW (Tvdad)
Registered Member Username: Tvdad
Post Number: 1 Registered: 10-2006 Posted From: 66.31.82.33
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 18, 2006 - 9:40 pm: | |
If I drain the collant out of the system will I cause any damage if I don't refill till spring? I live in southern New Hampshire. |
Jerry Liebler (Jerry_liebler)
Post Number: 232 Registered: 3-2005 Posted From: 67.141.38.217
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 18, 2006 - 10:09 pm: | |
Tom, It all depends on what you are draining as some will be left in the engine. If it was water and not a proper antifreeze mixture you could have freeze damage. However if what you are draining is an antifreeze mixture that won't freeze that should cause no problem. However it still would be better if you refilled with proper coolant and took it for a drive every month or so as this would reduce the possiilities of cylinder rust and bearing flat spots that prolonged idleness can cause. Regards Jerry 4107 1120 |
Post Number: 216 Registered: 9-2004 Posted From: 70.153.23.59
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 18, 2006 - 11:10 pm: | |
The water pump seals & other rubber in the system probably won't like drying out. Why not put proper coolant in it now? |
