Oil pans Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » November 2006 » Oil pans « Previous Next »
Bobh (Bobh)
Username: Bobh
Post Number: 9
Posted From: 204.116.186.20
Posted on Wednesday, November 22, 2006 - 11:47 am:
Is the oil pan different for a bus engine than a truck engine? ie: 6V92 going in an eagle.
Username: Bobofthenorth
Post Number: 116
Posted From: 64.110.227.34
Posted on Wednesday, November 22, 2006 - 12:20 pm:
Possibly but if it will fit and doesn't rub against anything I can't see why you would care.
Username: Rjlong
Post Number: 1115
Posted From: 67.181.163.170
Posted on Wednesday, November 22, 2006 - 12:55 pm:
Bob -
Coach oil pans are usually a little shallower than a truck's.
Truck engines sit up higher between the chassis rails, compared to a coach.
If you use a truck pan, just be aware of the lower ground clearance - especially entering driveways, etc.
FWIW & HTH. . .
JJ Woden (Jj_woden)
Username: Jj_woden
Post Number: 5
Posted From: 65.19.246.49
Posted on Wednesday, November 22, 2006 - 7:11 pm:
If it is a V-drive, doesn't the engine sit at an angle? And if so, won't the oil pan conform to this angle, including the oil pickup? Only asking questions, I do not know for sure.
JJ
Bob greenwood (Bob_greenwood)
Username: Bob_greenwood
Post Number: 374
Posted From: 4.226.108.34
Posted on Wednesday, November 22, 2006 - 7:19 pm:
Eagles are T-drive
Username: Pvcces
Post Number: 1016
Posted From: 65.74.65.54
Posted on Wednesday, November 22, 2006 - 9:17 pm:
You're right, JJ.
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
Ray Lala (Rayshound)
Username: Rayshound
Post Number: 79
Posted From: 68.201.216.135
Posted on Wednesday, November 22, 2006 - 10:01 pm:
Bob;
I had pulled a truck engine and it had a front sump which was bad for a (t) drive bus. The pan was also plastic! For a nonimal fee DD sold me a cast Aluminum rear sump pan for my S-60 to install in a bus. Ray
Bill Keller (Bill_k)
Username: Bill_k
Post Number: 4
Posted From: 67.140.40.135
Posted on Wednesday, November 22, 2006 - 11:33 pm:
Iam using a truck pan on my 8v92 in a mc8. It does not hang that low, I have thought about adding a skid shield, it would have to be heavy, at this point only a thought.
Bobh (Bobh)
Username: Bobh
Post Number: 10
Posted From: 71.192.96.61
Posted on Saturday, November 25, 2006 - 7:11 pm:
Thanks for all the replys. I thought the pan for a bus might be a little shallower. I'll have to look for one when I get the engine back home in a couple of weeks. It will be a good time to put new bearings in it if needed. Hey Tom, my father used to live in Ketchikan. It rained everytime I went up there to visit.
Username: Pvcces
Post Number: 1019
Posted on Saturday, November 25, 2006 - 9:29 pm:
Bobh, that's what it usually does around here, alright.
For some reason, we lost our rains this fall. I noticed that there were floods both north and south of us, instead. Do you suppose they went there?
Suncatcher
Ketchikan, Alaska
