Tranny problems Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2006 » December 2006 » Tranny problems « Previous Next »
Don Nichols (65fisher)
Username: 65fisher
Post Number: 1
Posted From: 67.141.149.169
Posted on Thursday, November 30, 2006 - 9:43 pm:
I have a 1965 GMC "Fishbowl". It has the 318 Diesel and the Vs2-8 tranny. I cannot get it to move. It appears to go into gear and I can rev the engine, but nothing happens. I am extremely new to this, so be gentle, but I really need to move this bus. Thanks for the help.
Don
Username: John_mc9
Post Number: 132
Posted From: 66.217.106.170
Posted on Thursday, November 30, 2006 - 9:59 pm:
Is it safe to assume you've managed to properly released
the parking brake, and the brakes have indeed released?
Bob greenwood (Bob_greenwood)
Username: Bob_greenwood
Post Number: 398
Posted From: 4.227.2.41
Posted on Thursday, November 30, 2006 - 10:26 pm:
we don't know how new you are, but you must push the button down,then press hard on the brake pedal after you are sure you have 120 pounds of air
Steve Souza (Steveggt)
Username: Steveggt
Post Number: 1
Posted From: 71.116.87.220
Posted on Friday, December 01, 2006 - 12:41 am:
Hi Don! If you're in gear but the bus doesn't move, you should feel it rock back and forth a bit. This means your brakes haven't released.
You probably have a F-N-R lever to the right of the driver's seat, or you might have a toggle switch on the left of the dashboard next to the air gauge to select F-N-R.
With the lever, a cable pulls the tranny into F-N-R. With the toggle, an air cyliner/piston selects F-N-R. In either case, once the desired direction is selected, there's about a 1 second delay, then you should feel the trans engage. It's just like your car...there's a bit of a delay from when you select (D) Drive to when it actually engages.
If you don't hear/feel the little "clunk", the tranny isn't engaged, and then we have to dig deeper...
Art Gill (Sandcastle)
Username: Sandcastle
Post Number: 19
Posted From: 208.11.184.64
Posted on Friday, December 01, 2006 - 7:54 am:
Try pulling up on the brake pedal. I have had mine stick enough to keep the brakes engaged.
Art
Brian Brown (Blue_velvet)
Username: Blue_velvet
Post Number: 402
Posted From: 72.19.152.144
Posted on Saturday, December 02, 2006 - 2:01 am:
As Steve said, you should hear the "clunk". When I had a Fishbowl w/ the VS2-8, sometimes the wire that connects to the tranny solenoid would come off. Was an easy fix.
One time it came off when I was negotiating a tight turn with several iterations backwards and forwards. So I ran back there to plug it in and FELT THE CLUNK the instant I did... it was still in DRIVE!
Luckily I caught up with the bus, since you've never seen a man cover 40+ feet so fast!
Brian "stupid bus tricks" Brown
presently driving a 4108-216 w/ V730
Longmont, CO
