John Elnitski (Ski43)
Registered Member Username: Ski43
Post Number: 1 Registered: 1-2007 Posted From: 71.58.59.233
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 09, 2007 - 2:06 pm: | |
I have a 1980 MCI 9, I have removed the A\C and plan to put the batteries for house power in the condensor bay to have air flow. Is it ok to place the inverter in the same place as the batteries or is this too dangerous, also how about a convertor |
Arnold J Molloy (Ayjay)
Post Number: 58 Registered: 10-2005 Posted From: 151.203.103.166
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 09, 2007 - 3:35 pm: | |
I wouldn't put "ANY" spark producing device in close proximity to any battery, not even AGM's..... The Hydrogen gas produced has a nasty habit of exploding.... Remember the Hindenburg! |
J.C.B. (Eagle)
Registered Member Username: Eagle
Post Number: 94 Registered: 12-2000 Posted From: 74.130.41.171
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 09, 2007 - 3:37 pm: | |
John if your inverter has a charger on it you would not need a converter. |
Post Number: 980 Registered: 12-2000 Posted From: 69.156.124.200
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 09, 2007 - 3:55 pm: | |
I would also not want to expose the delicate electronics of my inverter to the corrosive fumes of the batteries. happy coaching! buswarrior |
WILLIAM D. WATKINS (Sivrtnge2)
Registered Member Username: Sivrtnge2
Post Number: 22 Registered: 11-2006 Posted From: 69.164.197.32
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 09, 2007 - 4:08 pm: | |
John, I put my Xantrex 3012 inverter charger in a compartment beside my batteries. they have been that way for over a year. Here is the kicker. I used a 4 x 8 sheet of silver sided insulation board as a divider. On the battery side, I installed a piece of pvc pipe, a "T" and 2 round ac duct vents to vent the gases out of the compartment. I cut the board down to size and made a box to separate the inverter/charger from the battery bank. My compartment is about 30" x 14". Now for everyone else who reads this, I did it this way because this was my only option. I am not saying that it won't hurt anything, ...just saying it has been this way for over a year with no problems. I discussed this with a coach builder in Nashville, TN. he said it would be fine. -- BILL |
James Stacy (Jimstacy)
Post Number: 18 Registered: 1-2001 Posted From: 71.150.84.248
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 09, 2007 - 10:28 pm: | |
Put Hydrocaps on the batteries and there will be no fumes. My inverter has been in the same compartment with three 8D's for 6 years - no problem, no corrosion anywhere. |
Post Number: 266 Registered: 9-2004 Posted From: 65.23.106.193
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 10, 2007 - 8:18 am: | |
Hydrocaps tell to remove the caps when equalizing or during heavy charge/ discharge rates, what do you do about the gasses while the caps are removed? There was also something about the life span of the hydrocap. How will you know when to replace them? Seems better to avoid the potential problems if at all possible since an inverter is more than pocket change for me. After reading about hydrocaps & the water-miser caps, I prefer the water-miser because you can ignore them & let the inverter do it's charging thing without intervention. kyle4501 |
