Registered Member Username: Chucks
Post Number: 1075 Registered: 10-2003 Posted From: 67.101.142.167
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 18, 2007 - 12:18 pm: | |
Would you think there are any issues with cutting the backbone in almost freezing weather? Yes, I'm (for once) planning ahead for summer and building the rooftop (carbunkle) framework. I have all my 1.5" 14ga sq. tubing, cut, primed, ready to go. Two 5' pieces on each side of the existing backbone to be welded into place *before* cutting the spine. I can tell that the entire bus structure has 'shrunk' ever so slightly in this weather compared to summer, and am wondering if there are any issues I should take into account before I have an "oh sh**t" moment when things warm up ??? |
Bob greenwood (Bob_greenwood)
Post Number: 565 Registered: 7-2006 Posted From: 64.136.49.228
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 18, 2007 - 12:35 pm: | |
OR....you could offset the hole & not touch the backbone |
Post Number: 1076 Registered: 10-2003 Posted From: 67.101.142.167
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 18, 2007 - 1:15 pm: | |
Bosh. ;) |
Cliff (Floridacracker)
Post Number: 309 Registered: 7-2004 Posted From: 65.33.17.192
Rating:  Votes: 2 (Vote!) | Posted on Thursday, January 18, 2007 - 2:57 pm: | |
Chuck, The amount of contraction and expansion over the size of that a/c opening is very, very small. Just get the steel at the same outside/inside temp before cutting and you should be fine. Cliff |
Post Number: 1078 Registered: 10-2003 Posted From: 68.165.11.248
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 19, 2007 - 1:20 pm: | |
Thanks for the confirmation, Cliff. Every now and then I come across something that I had no idea about and didn't want this part of the project to be one of those! And thank you too, Mr. "Greenwood!" It is a valid suggestion but I'm just too much of an inline guy for that. I've done plenty of wierd stuff in other areas though! |
Post Number: 568 Registered: 7-2006 Posted From: 64.136.49.228
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 19, 2007 - 4:22 pm: | |
hang in there mr. bosh...in about 20 years,you will have it done  |
Post Number: 1079 Registered: 10-2003 Posted From: 67.101.142.6
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 19, 2007 - 6:29 pm: | |
Yeah, that's about right the way I'm going. . . And it'll still look like a box of saltine crackers!  |
