Larry D Baker (Lbaker4106)
Registered Member Username: Lbaker4106
Post Number: 43 Registered: 5-2005 Posted From: 68.63.13.242
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, January 22, 2007 - 2:10 pm: | |
My friend has a mci but being a GM busnut I do not know where to find the model and serial number. Any help? |
Ed Jewett (Kristinsgrandpa)
Post Number: 285 Registered: 2-2003 Posted From: 64.24.208.18
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, January 22, 2007 - 6:10 pm: | |
These people have some info about bus ID's. http://busforsaleguide.com/mci.htm Ed. |
Post Number: 1169 Registered: 12-2000 Posted From: 71.195.127.101
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, January 22, 2007 - 10:09 pm: | |
Larry - When originally built, you'll find a plaque similar to our GMCs riveted above the driver. There should also be a plaque riveted to the bulkhead, centered above the squirrel cages in the blower compartment - you'll need a ladder to climb up and clean the crud off to read it. FWIW & HTH. . .
Douglas Wotring (Tekebird)
Post Number: 65 Registered: 10-2004 Posted From: 69.136.90.146
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, January 22, 2007 - 10:46 pm: | |
Also should be one on the inside of the battery compartment door |
