Carter D Forbes (Eagle_318)
Registered Member Username: Eagle_318
Post Number: 5 Registered: 12-2006 Posted From: 67.101.106.186
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, February 04, 2007 - 5:49 pm: | |
Does anybody know what needs to changed or cut out to put a roadranger 10 speed in a 1970 eagle 8v71 manual 4 speed. |
Bob greenwood (Bob_greenwood)
Post Number: 638 Registered: 7-2006 Posted From: 64.136.49.228
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, February 04, 2007 - 5:56 pm: | |
I've got a 12 speed overdrive that I will sell you...standard H-pattern three times,called airshift.500.00 & you pick-up |
Mark Renner (Boomer)
Post Number: 29 Registered: 11-2006 Posted From: 12.180.53.193
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, February 04, 2007 - 11:16 pm: | |
I have a Spicer 1062B 6 speed transmission in beautiful shape for 400.00. Same gearbox used in 1980's vintage Prevosts and MCI's. Includes the clutch assembly. |
Post Number: 6 Registered: 12-2006 Posted From: 67.101.106.186
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, February 05, 2007 - 12:26 am: | |
I was wanting to know more about installing a 10 speed roadranger in a 1970 Eagle 05, now it has a 4speed manual. Bob greeenwood could you tell me more about 4x3 12 speed? Is it a simple change out or is there alot of frame cutting and modifying required? Thanks |
Post Number: 7 Registered: 12-2006 Posted From: 67.101.106.186
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, February 05, 2007 - 12:35 am: | |
What I really want to know is there a manual gearbox that has 10+ gears that will FIT in place of my 4spd with the least modifacation? In a 1970 eagle 05 w/8v71 Carter |
Post Number: 639 Registered: 7-2006 Posted From: 64.136.49.228
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, February 05, 2007 - 6:03 am: | |
almost all swaps you will have to change driveshaft lenghts.the standad H-pattern thru 4 gears,then you hit a air switch on the shifter & go thru the same four again,then you hit another switch on the shifter & go thru the same 4 again,not a simple job, probably needs 200 feet of air hose ,comes with the shifter to install next to driver.if I remember correctly top gear is .84 overdrive,& I imagine you wouldn't use the first 4 gears unless you were tackeling something really steep from take off,I have an extra 4 speed & it apears to be 'about' the same length,but much fatter trans than the 4 speed,it would take someone with knowledge & time to hook it up |
larry currier (Larryc)
Post Number: 11 Registered: 2-2007 Posted From: 207.200.116.13
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, February 05, 2007 - 10:21 pm: | |
Carter. It will fit fine. 9 speed 10 speed 13 speed all fit. The only hard part is the change over to 1 shift bar from 2 assuming you now have a 4 speed stick. |
Larry Baird (Airhog)
Registered Member Username: Airhog
Post Number: 117 Registered: 1-2001 Posted From: 71.102.5.160
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 06, 2007 - 11:19 am: | |
I am just completing a change in my MC-7 from 4 speed to a 10 speed RTO (not all 10 speeds have overdrive), I changed to a pull type clutch, adapter plate on your bell housing and the small trans clutch housing worked for me. |
Harry Gerritse (Tinlizzy)
Registered Member Username: Tinlizzy
Post Number: 2 Registered: 4-2003 Posted From: 142.179.148.122
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 07, 2007 - 10:57 am: | |
Larry, do you have any pics of transmission change? Doing my MC7 soon..I want to go with a 10 speed Thanks Harry |
Post Number: 118 Registered: 1-2001 Posted From: 71.102.5.160
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 07, 2007 - 11:57 pm: | |
This is one of the assembly befor installation. To clear the turbo we cut a 16" sq. out of the floor and ran the shift rod (from a 5 speed Prevo) down the tunnel and out the floor.  |
