Onan gen set Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » March 2007 » Onan gen set « Previous Next »
bernie newcomb (Newk)
Username: Newk
Post Number: 12
Posted From: 152.163.100.13
Posted on Monday, March 12, 2007 - 8:40 pm:
does anyone know a good onan mechanic in south fla ? the dealer i talked with could not help me
thanks
Newk
Frank Rowe (Frankid)
Username: Frankid
Post Number: 11
Posted From: 63.239.248.1
Posted on Monday, March 12, 2007 - 8:55 pm:
Repairing an Onan is like fixing your lawn mower. If you do not have a manual, get one soon. If ya tell the problem, maybe we can make it all better. Frank
Username: Newk
Post Number: 13
Posted From: 205.188.116.13
Posted on Tuesday, March 13, 2007 - 12:38 am:
when a load is increased, the gen pulls down, if the load is decrased, the gen speeds up. under normal loads it will show 118 V at 60 hertz. if the ac compressor kicks off, the voltage will go to 150 volts and i have to shut it down.
Username: John_mc9
Post Number: 244
Posted From: 66.217.105.205
Posted on Tuesday, March 13, 2007 - 12:57 am:
Most gensets have two governor adjustments. One to set the
base RPM/voltage, and the other to adjust the sensitivity.
The sensitivity is usually adjusted by changing the amount of
tension on the spring. The control rod (and spring) will have
either an adjustable rod, or positions to move it to.
The idle screw will set both the no-load power (rpm),
and the power that the sensitivity control will bring it back to.
You'll need a voltmeter to set both.
(^%$*##~ even I can't understand that)
Maybe someone else can 'splain it better.....
Username: Jackconrad
Post Number: 528
Posted From: 76.1.180.218
Posted on Tuesday, March 13, 2007 - 9:10 am:
Bernie,
He is not a full time mechanic, but I believe Dave Hartley has twisted a few wrenches on Onans. You might give him a call. Jack
Username: Drdave
Post Number: 739
Posted From: 72.189.203.211
Posted on Tuesday, March 13, 2007 - 10:51 am:
The throttle return spring is either stretched or missing.
The governor can exert a lot of pressure on the throttle linkage. If the return spring is weak, broken or missing the governor cannot pull back quick enough when the load is reduced suddenly.
So by changing or adding a stronger return spring to close the throttle faster should solve the problem.
The spring should yank the throttle butterfly close very fast and firmly so it exactly tracks the governor lever. That pull-back must be there or over-revving and overvoltage will be a big problem.
ACE hardware should have an assortment of springs. You probably need a 2 to 4 lbs pull spring in about 2 inches long.
Look on the governor lever and see what shape spring is on there that pulls it to the off position when the engine is not running.
That is the return spring. Take that to ACE Hdwr
and find one like it that is stronger.
You will then need to reset the governor speed accordingly.
60 Hz on a meter. The voltage may vary a bit but the frequency should be bouncing from 58 to 63 hz
but not much more of a swing. No load just at the upper edge of 60 hz with medium load it should sit at around 59/60 hz.
When the load drops the freq may jump to 63 hz and then stabilize quickly.
Jack,
I am 3 hours away from him, But good try anyway..
Dave....
Jim Wilke (Pd41044039)
Username: Pd41044039
Post Number: 126
Posted From: 69.77.151.82
Posted on Tuesday, March 13, 2007 - 9:11 pm:
Actually, if it's a gasoline genset, it could be nothing more than a varnished up carb. When they get that way, you can not stabilize the frequency no matter what you do. They MIGHT have a fairly sweet spot at a certain (usually max) load but as soon as the load changes, vroom, vroom, vroom. If that were it, the best fix is a NEW carb. I have rebuilt a couple and about half the time you can not get it to work right again once badly fouled by old gasoline.
Jim-Bob
Username: Ace
Post Number: 476
Posted From: 216.9.250.6
Posted on Wednesday, March 14, 2007 - 8:06 am:
NCBOB works on onan's and I think he is still in central florida. I've seen him in action at the rally. Looked like one of those wild animal shows where one animal devours another! If he sees an onan, the guy gets down right crazy! :-)
Ace
Bob Wies (Ncbob)
Username: Ncbob
Post Number: 204
Posted From: 66.174.93.105
Posted on Wednesday, March 14, 2007 - 8:40 am:
Bernie...try Don Hillman Inc. in Fort Lauderdale. They've been in business since the 60's and know their stuff. How do I know them? I was Service Manager there for 9 years.
NCbob
Post Number: 129
Posted on Wednesday, March 14, 2007 - 10:46 am:
Bob's right. Don Hillman is very good! I just offered the Fort Myers guy because Bernie's profile said he's in Ft. Myers.
Jim-Bob
