PEX Tubing Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » April 2007 » PEX Tubing « Previous Next »
Mike Stegeman (Mike_s)
Username: Mike_s
Post Number: 1
Posted From: 75.4.39.230
Posted on Sunday, March 25, 2007 - 6:59 pm:
Hi
I am installing a hydronic heating system in by bus. I am installing 4 toe-space heaters and will run individual PEX lines to each heater. What I would like to know is, should I use 1/2 ” or 3/4" lines, and should they have the O2 barrier or is regular PEX
Thanks Mike
Username: Dmd
Post Number: 157
Posted From: 71.125.61.116
Posted on Sunday, March 25, 2007 - 8:24 pm:
Mike, use the barrier only for heat. The 3/4 would be better but its hard to bend. You can use the large sweep elbows or 2 45's to reduce the flow resistance.
Username: Jackconrad
Post Number: 534
Posted From: 76.1.180.218
Posted on Sunday, March 25, 2007 - 8:32 pm:
Mike, where did you find the toe kick units? Jack
Username: Joemc7ab
Post Number: 93
Posted From: 66.38.159.33
Posted on Sunday, March 25, 2007 - 8:39 pm:
Mike
My suggestion to you would be be to go with the largest size available 1" is available as far as I know, which would lower your flow resistance, thus lowering the demand on your circulating pump. The difference in headloss per 100 ft of lenght at 140 F and 2 GMP of flow is 16 times lower in 1" PEX as compared to same condition in 1/2" PEX. Also make sure that everything is run in parallel, not series. Go for Bpex if there is anything in the system that could rust.
This link has lots of good info charts tables etc.
www.radiantsite.com
Joe.
Jerry Campbell (Jerrync)
Username: Jerrync
Post Number: 70
Posted From: 69.132.150.103
Posted on Sunday, March 25, 2007 - 8:42 pm:
Jack I got mine at Campbell and Brown in Charlotte NC at about 95.00 each
(Message edited by Jerry@nc on March 25, 2007)
Username: Mike_s
Post Number: 2
Posted on Sunday, March 25, 2007 - 10:09 pm:
Jack , I got mine directly from Aqua-Hot through there parts department. Cost was $ 120.00 each. You can see them on there web page ...http://www.hydro-hot.com/rv-lifestyles-accessories.htm
Ron Walker (Prevost82)
Username: Prevost82
Post Number: 272
Posted From: 69.19.14.16
Posted on Monday, March 26, 2007 - 12:03 am:
Hi Jack ...I installed a hydro-hot in my bus. I bought a kit from Vehicle Systems. They sent me high temp PEX that was 5/8 ID, rated for 200+ degs. We have 3 Cozy 3 heaters (toe-kicks) in the salon and 1 each in the bathrm & bedrm. Ran the PEX down the curb side walls of the bus ...I strap the wall with 1x2 and added rigid insulation and the Pex (hot and return) run down the wall in this cavity
Ron
Username: Dnick85
Post Number: 91
Posted From: 68.45.178.44
Posted on Monday, March 26, 2007 - 12:24 pm:
Hi Mike,
There is also Aluminum PEX [AL-PEX] that holds it's shape when you bend it. For close quarters like a bus it may be a better choice. As far as the pex size, the opening of your toe kicks will determine the resistance. If you are home running your supply and return, then stick with the diameter of the toe-kicks inlet and outlets sizes. Going larger on the tubing will not help flo if your restricted to 1/2" on the kicks.
Good Luck
Nick-
Username: Mike_s
Post Number: 3
Posted on Monday, March 26, 2007 - 5:51 pm:
THANKS ALL !!! Mike
Mike (Mikemc9)
Username: Mikemc9
Post Number: 18
Posted From: 4.242.183.234
Posted on Monday, March 26, 2007 - 10:14 pm:
I too am looking for a hydronic heating system for my MC9. Any other types or home made rigs besides the Hydro(Aqua)-Hot systems. Like most others, looking to save a buck, that $6,000+ sure hurts.
Thanks, Mike
Post Number: 537
Posted on Tuesday, March 27, 2007 - 8:00 am:
Taking the advice of Ray Edwards, another busnut, I contacted Nick at Nimco in NJ and purchased a used ProHeat 45,000 BTU unit. I have not got mine installed yet. After purchasing the proheat, Ray went to a Salvage yard and bought a couple heater cores, made boxes for them and added a couple "muffin" fans. Total cost of the system: approx. $600. His system is bus heat and engine preheat only, it does not tie into his hot water heater. Jack
Brian Elfert (Belfert)
Username: Belfert
Post Number: 33
Posted From: 132.148.80.215
Posted on Tuesday, March 27, 2007 - 9:04 am:
Be aware that the Proheat units from Nimco are pulls from trucks and buses and may not be pretty. Nimco chops all the wiring harnesses and fuel line right at the unit so the wiring will require splicing.
The price is good so the issues aren't unexpected.
I haven't used mine yet, but I assume it works.
The heater cores with fans that I bought only have 1/2" PEX connections so no real reason to go bigger than that for me.
Brian Elfert
RTAntonio (Gr8njt)
Username: Gr8njt
Post Number: 1
Posted From: 68.39.161.3
Posted on Thursday, March 29, 2007 - 8:10 am:
How much is NIMCO asking for the Proheat units pulled from other trucks and buses? Thanks
Post Number: 540
Posted on Thursday, March 29, 2007 - 9:40 am:
I don't give prices I paid because with supply and demand, prices change. Call 1-800-526-8055 and ask for Nick. Jack
Username: Kyle4501
Post Number: 307
Posted From: 65.23.106.193
Posted on Monday, April 02, 2007 - 4:50 pm:
Your tubing size requirements will depend on the flow requirements, length of run, desired pressure drop.
The pressure losses in the system are cumulative.
The pressure drop in 100 feet of pipe for 1gpm flow (water at 60F)
For 3/8" pipe (0.493" id) = 1.85 psi
for 1/2" pipe (0.622" id) = 0.60 psi
The pressure drop in 100 feet of pipe for 5gpm flow (water at 60F)
For 3/8" pipe (0.493" id) = 36.7 psi
for 1/2" pipe (0.622" id) = 11.2 psi
(from CRANE technical paper No. 410)
So you may need larger tubing for satisfactory performance, it depends on how YOUR system is designed. The larger tubing holds a larger volume of water, so that will require a larger expansion tank. Raising the operating temp reduces flow required (which reduces line size & tank requirements) but may put more stress on the seals & tubing. Etc. . . . .
Ain't nothing as simple as it looks.
One of these days, I'll get brave & tackle this on my bus.
Post Number: 111
Posted From: 4.240.144.79
Posted on Monday, April 02, 2007 - 8:31 pm:
FWIW...just a bit of interesting information...today I purchased three bronze fittings; a 2 inch nipple (1/2), a 3/4 to 1/2 bushing and a 3/4 Street EL. Plumbing supply house, not a hardware store. Nearly $16...(wow, I said). The counter person said that is nothing compared to copper. She went on to inform me a 1/2 x 20 foot stick of copper.........are you ready for this??? $70.00 (seventy!!!)
My coach is plumbed with 1/2 and 3/4 inch copper thruout. Brass or bronze fittings. Done mostly 5 years ago. I chose that instead of Pex because of $$$ invested. (so far, not a single leak) Sounds like a bad choice today if one is on a budget. They confirmed and said that most plumbing applications today are going that way....to Pex.
Times....they are a'changin'! :-)
