dutch (Dutch)
Registered Member Username: Dutch
Post Number: 41 Registered: 2-2007 Posted From: 216.9.250.6
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 01, 2007 - 12:30 pm: | |
He folks If I ever needed new ones where do I get them.Did anybody ever put on new ones???is there a brand out there that fits the 4106.??? I took my tires of and saw them and they look pretty normal to me,,,meaning that I think I can find new drums easily. Anyway Still learning one issue at a time. Dutch |
Post Number: 512 Registered: 10-2003 Posted From: 71.58.117.21
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 01, 2007 - 12:47 pm: | |
Not a problem yet Call Luke. Also you might get them from a bigger local truck parts distributor if you supply the GM part number. |
larry currier (Larryc)
Post Number: 76 Registered: 2-2007 Posted From: 207.200.116.13
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 01, 2007 - 3:49 pm: | |
Dutch,did you see the inside or the outside of the drums when you took the tires off? Does that 06 have outboard drums? |
dutch (Dutch)
Post Number: 42 Registered: 2-2007 Posted From: 66.68.98.151
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 01, 2007 - 5:07 pm: | |
he larry i only saw the outside havent had a chance to get to the inside. next week in will problably get to that. |
Post Number: 513 Registered: 10-2003 Posted From: 71.58.117.21
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 01, 2007 - 6:19 pm: | |
The 06 has outboard drums. After removing wheel,s there are 4 or 6 philips head flathead screws holding the drum to the hub. Sometimes these can be a #%<*& to remove if someone hasn't used antiseize on them. But there are tricks to get them loose. |
