4107 AC gone and pump on motor needs ... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » April 2007 » 4107 AC gone and pump on motor needs connected? « Previous Next »
Mike Fulper (Seeburgrepair)
Username: Seeburgrepair
Post Number: 2
Posted From: 75.89.114.135
Posted on Sunday, April 01, 2007 - 7:48 pm:
I would think the AC hydraulic pump on the motor needs the ends connected so the fluid circulats in the pump.?
Also since the AC is not working .. i should be able to disconnect the PTO shaft off the motor to the AC unit.. thing looks like it could fly off and do some damage.. dont see where it would hurt to take of the drive shaft to AC...right?
thanks, Mike in Ohio 740-638-5059
larry currier (Larryc)
Username: Larryc
Post Number: 78
Posted From: 207.200.116.13
Posted on Sunday, April 01, 2007 - 8:43 pm:
Man, Take it off before it flys off!
Arthur N.Gaudet (Runcutter)
Username: Runcutter
Post Number: 4
Posted From: 76.185.242.7
Posted on Sunday, April 01, 2007 - 9:38 pm:
Mike, nothing wrong with taking the A/C drive shaft off - the one from my 4107 is sitting in my baggage bay. It also eliminates a small amount of parasitic drag, at least a theoretical increase in fuel mileage.
Now, I'm glad to know where those electrical drawings went - I was thinking of them myself (one to stay in the coach, one to stay in the house). I'm glad they went where they'll be used.
Arthur
Post Number: 3
Posted From: 75.117.235.192
Posted on Monday, April 02, 2007 - 9:01 pm:
thanks, i assume i need to route the hydraulic pump lines from the resivor to the pump and complete the circuit so the pump dont burn up. if its not already...:-(
Jerry Liebler (Jerry_liebler)
Username: Jerry_liebler
Post Number: 244
Posted From: 67.140.162.169
Posted on Monday, April 02, 2007 - 9:21 pm:
Mike,
Why not remove the Hydraulic pump and replace it with a cover plate. You don't need the drag of it either. Just be sure it's the one dedicated to the condensor fan & not the power assist steering.
Regards
Jerry 4107 1120
