Camshafts Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » April 2007 » Camshafts « Previous Next »
Mark Karlsson (Flying_fishbowl)
Username: Flying_fishbowl
Post Number: 11
Posted From: 67.188.211.79
Posted on Friday, April 06, 2007 - 12:36 am:
I'm thinking about buying some 6V92 camshafts. Can anybody tell me if these camshaft part numbers are the smog cams or not?
3-EP-006
3-EP-005
These are left-hand rotation cams. Thanks!
Muddog16 (Muddog16)
Username: Muddog16
Post Number: 342
Posted From: 4.225.94.54
Posted on Friday, April 06, 2007 - 4:43 am:
Mark I ran those numbers and I don't show them as valid numbers! The ones I came up with were these:
DM-5107313 CAMSHAFT RIGHT BANK, R/H
DM-5107314 CAMSHAFT LEFT BANK, L/H
DM-5108112 CAMSHAFT RIGHT BANK, R/H
DM-5108111 CAMSHAFT LEFT BANK, L/H
6V92 Camshafts
The person to call would be Sam Caylor in Kansas here is his contact information:
Caylor Supply - Used MCI Bus Parts
4712 Rock Creek Rd., Rantoul, KS 66079
785-878-3405 Fax 785-878-3427
Sam knows DD engine parts and he doesn't mind helping you out when you need information! On those numbers above just take the DM- out and you have DD part numbers!
Pat
james dean boggs (Jd_boggs)
Username: Jd_boggs
Post Number: 109
Posted From: 75.80.240.120
Posted on Friday, April 06, 2007 - 10:39 pm:
Muddog:
The numbers you listed, which are the California cams and which are the Federal cams? I'm in search for Federal L/H cams.
Thanks.
