Larry D Baker (Lbaker4106)
Registered Member Username: Lbaker4106
Post Number: 47 Registered: 5-2005 Posted From: 209.153.142.38
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, April 07, 2007 - 10:31 pm: | |
I am broke down in Tenn. with over heating. I replaced the water pump but not sure if there is a right and left hand pump. Still gets hot and rad. is cool so have rad. out getting rodded. Any other suggestions? Now do not have any heat up front. |
larry currier (Larryc)
Post Number: 85 Registered: 2-2007 Posted From: 152.163.100.13
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, April 07, 2007 - 11:26 pm: | |
Hope its not a cracked head or liner. If your pumping compression into the water, the air will push the coolant out the overflow and you can't keep it cool. Sounds like the heater lines are air locked, not a good sign,(where did the air come from?) If you looked at the fins on each water pump and they are the same, I think you are ok. If you have a dry liner engine you can probably rule the bottom end out. Do you have any water/antifreeze in the oil? I'm assuming you have checked the thermostat situation out. |
evan (Legaleagle82)
Registered Member Username: Legaleagle82
Post Number: 8 Registered: 12-2006 Posted From: 69.245.4.209
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, April 07, 2007 - 11:51 pm: | |
Larry, you didn't say where in Tenn, but I'm in Nashville if you're close by and need any help. I agree, you've got air in the system for some reason. |
Post Number: 1880 Registered: 1-2001 Posted From: 75.108.78.129
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 08, 2007 - 8:59 am: | |
It is very easy to get air in the system when replacing water pump, which you state you did. Must get all the air bled out of the system including the heater hoses. Richard |
Hans (Buellhans)
Registered Member Username: Buellhans
Post Number: 34 Registered: 2-2007 Posted From: 205.250.41.167
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 08, 2007 - 2:20 pm: | |
pump no matter the way she turns ,make sure all the air is out . there is actually bleeds all over the cooling pipes as well the block look for them you will find them . |
Post Number: 48 Registered: 5-2005 Posted From: 209.153.174.145
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 08, 2007 - 3:21 pm: | |
Bus is in Collinwood Tenn. An 8v71 has dry sleeves, there is no water/antifreeze in the oil, and the thermostats were changed with the water pump. Air probably came from changing the pump and thermostats. Not sure how to get the air out of the heater lines. Don't seem to have pressure in the system when running but can't check while running down the road. |
Douglas Wotring (Tekebird)
Post Number: 155 Registered: 10-2004 Posted From: 71.59.75.212
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 08, 2007 - 3:50 pm: | |
there is a bleed at the heater core and Defroster core |
