New pump installed correctly? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » April 2007 » New pump installed correctly? « Previous Next »
Tom Mason (Manasst)
Username: Manasst
Post Number: 2
Posted From: 71.31.172.141
Posted on Sunday, April 08, 2007 - 9:38 pm:
i had some leaks around the shaft on the hydraulic fan pump on my 91 Eagle. the pump guy said the shaft was shot, none available, so i bought the new one from jefferson. since i took the old one out, i thought i'd try my hand at putting the new one in.
How much play on the belt?
should i put some loctite on the bolts on the hoses, pulleys, or mount?
so far no leaks showing and the fans do seem to be working ok (knock on wood).
any hints for installing this appreciated.
