Insulation ? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » April 2007 » Insulation ? « Previous Next »
Ken Turner (Pipesusmc)
Username: Pipesusmc
Post Number: 67
Posted From: 71.113.40.119
Posted on Saturday, April 21, 2007 - 11:18 am:
http://www.insulation4less.com/
I just bought a roll of insulation for the bus, from the above link..........They recomend having an airspace of at least 3/4".
My ? is, I have large amount of ceiling tile about 1.1/2" thick fiberglass, aluminum foil one side fabric on the other side. If I stuff this AND the 1/4 " new insulation into the bus frame (sides above deck) can I consider the FIBERGLASS as air space???...........TIA Ken.
Username: Chessie4905
Post Number: 532
Posted From: 71.58.117.21
Posted on Saturday, April 21, 2007 - 11:44 am:
They sell this stuff a Lowes also... the dead air space that they recommend to be used with it is what gives such a high R value. Without the air space, it gives little R value. Chech the info on the same stuff at Lowes; make sure you read all the info that comes with it.
Username: Drdave
Post Number: 760
Posted From: 72.189.203.211
Posted on Saturday, April 21, 2007 - 12:44 pm:
Foam panels have most of the airspace inside the foam itself.
Fiberglass conducts heat much better without that extra airspace. aka: Not as good as foam (ever)...
And foam won't make you itch....
Ed Jewett (Kristinsgrandpa)
Username: Kristinsgrandpa
Post Number: 307
Posted From: 64.24.214.102
Posted on Saturday, April 21, 2007 - 3:30 pm:
I would try an experiment if I were you.
Do a small section with the ceiling tile, and another small section without the ceiling tile, using the foil with both. Measure the surface with a noncontact thermometer and you should have the answer.
Doing it on the sunny side of the coach should be the best.
This has come up before, so please post the results if you do a test.
Ed
(Message edited by kristinsgrandpa on April 21, 2007)
