Post Number: 126 Registered: 7-2006 Posted From: 4.240.213.139
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, April 21, 2007 - 7:23 pm: | |
Is there a way (tool-meter,???) to check RPM on a generator other than installing a Tachometer? Every once in a while I do a "tune up" including changing filters, plugs, etc and would like to reset, or at least check for reset. 'ppreciate it! ... RCB '64 Crown Supercoach (HWC) |
Post Number: 1884 Registered: 1-2001 Posted From: 75.108.78.129
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, April 21, 2007 - 8:57 pm: | |
A frequency meter is the best way to set the rpm. Generally about 61 hertz at no load and 59 at full load. Many volt ohm multimeters have a frequency setting also. Richard |
Post Number: 333 Registered: 1-2005 Posted From: 72.40.12.186
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 22, 2007 - 9:04 am: | |
RCB KILL-A-WATT METER see--> http://www.the-gadgeteer.com/review/kill_a_watt_electric_usage_monitor_review http://www.amazon.com/dp/B000IB63HA/ref=nosim/?tag=dealtime-ce-feed-20&creative=380333&cre ativeASIN=B000IB63HA&linkCode=asn http://www.smarthome.com/9034.html http://www.supermediastore.com/kilwateldet1.html Pete RTS/Daytona Don't you just hate it when SOMEONE gives you only half an answer ?? (Message edited by pete rts/daytona on April 22, 2007) |
gary throneberry (Garhawk)
Registered Member Username: Garhawk
Post Number: 3 Registered: 3-2007 Posted From: 72.156.222.253
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 22, 2007 - 9:14 am: | |
hi rcb start generator. plug in electric clock you have determined to be reasonably correct. use stop watch to check clock accuracy. when the big hand is on twelve, start the stop watch. after one minute on the stop watch the clock should equal. if not, adjust generator rpm accordingly. gary t'berry |
Tony Gojenola (Akbusnut)
Registered Member Username: Akbusnut
Post Number: 14 Registered: 11-2006 Posted From: 24.237.217.192
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 22, 2007 - 3:32 pm: | |
Here's another handy gadget to have around that will do what you want - and a lot more. I keep mine plugged in all the time, and it has alerted me to campground power problems a couple of times in the middle of the night. Nobody should be without a monitor of some kind. tg http://store.boatnrv.com/boatnrv/details.php?ITEM=3620020 |
Post Number: 130 Registered: 7-2006 Posted From: 4.240.213.245
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, April 23, 2007 - 10:30 am: | |
Many thanx for the responses...as usual, what makes this board so great!!....and thanx to Ian. RCB |
