Transmission removal? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » April 2007 » Transmission removal? « Previous Next »
carl white (Carl_mci_9)
Username: Carl_mci_9
Post Number: 16
Posted From: 208.108.100.211
Posted on Wednesday, April 25, 2007 - 10:18 am:
I have removed the transmssion and got the new one ready to put in.
I need to switch the plate that the universal bolts to and is also where the speed sensor is
It is held on by a 2 and 3/4 inch nut.
Any tricks to get it off and where did you get a wrench or socket that big to remove it. rental places here in town don't even have one that large.
thanks carl
Mel La Plante (Mel_4104)
Username: Mel_4104
Post Number: 28
Posted From: 208.181.100.2
Posted on Wednesday, April 25, 2007 - 11:02 am:
Carl, take all the pieces to your local larg truck dealer such as freight liner and have them change it over for you. they will have all the tools reguired such as the socket and the tourqe wrench that will bring it to the right specs. when replaced. it is very importany that this nut is on proper or it may shake loose and do a lot of damage, the mony spent is well spent.
Post Number: 17
Posted From: 208.108.100.213
Posted on Wednesday, April 25, 2007 - 12:50 pm:
Mel:
Thanks for your quick reply.
I have a MCI repair center close by
I will talk to them and see if they will do it
if they will not I will go to a truck center.
carl
JR Lynch (Njt5047)
Username: Njt5047
Post Number: 151
Posted From: 69.132.226.200
Posted on Wednesday, April 25, 2007 - 7:25 pm:
That nut probably torques at 300 lbs or more.
As Mel says, this ain't a home job...unless you have the stuff to do it with. It will come off using a 1" impact. The same one that's used to remove the wheels. NAPA, Snap-On, Matco, Cornwall all have the sockets you need to remove it. A fixture will have to be fabricated to hold the flange for removal and tightening. Definitely a job for an Allison dealer.
Best, JR
