Parking Brake Drum and Shield. Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2002 » March 2002 » Parking Brake Drum and Shield. « Previous Next »
Paco Express (206.28.236.48)
Posted on Tuesday, March 05, 2002 - 7:25 pm:
I am currently reinstalling the Parking Brake (Johnson Brake) on my 1960 GMC 4104. I have purchased all parts except Brake Drum and Shield. I would appreciate any assistance in locating these two parts. Luke with US Coach had all parts except the Drum and Shield.
Jim Stacy (32.101.44.188)
Posted on Tuesday, March 05, 2002 - 9:06 pm:
Call Garry Dean, (919) 383-4780
Jim Wilke (205.188.192.49)
Posted on Thursday, March 07, 2002 - 10:13 pm:
Do you have spring brakes on your 4104? If not, you should. And if you do you don't need the parking brake.
That being said, I would have given you my drum but I threw it away, thinking nobody would EVER want that. (Rest of my system was already gone.)
By the way, I had to press it off the output flange. I thought it was just held with the bolts that go thru it. Took em off & it still wouldn't come off. Had to remove flange/drum assy from the transmission & press off. By the way, the nut that holds the output flange on is to be torqued to either 600 or 800 foot lbs!
Jim-Bob
1959 4104-4039
FAST FRED (209.26.87.95)
Posted on Friday, March 08, 2002 - 5:22 am:
"Do you have spring brakes on your 4104? If not, you should. And if you do you don't need the parking brake."
Not sure I agree with this .
I have looked at the two systems ,
Spring or ICC and chose to stick with the ICC.
When there is a falure with spring brakes, your stuck right there , middle of the road, an intersection, whatever.
With the ICC the coach can at least be CAREFULLY moved , as the Johnson bar is equal to one real brake, enough to stop you in first getting off the road.
Also I dont like having the drums distorted by the release , system , where both the springs AND the air is pushing on the drums to release the springs.
Finally on an 06 , there is loads of welding to install spring brakes.
Dont know any welders that want to have a liability problem forever.
Sometimes what is forced on an industry , might not be the best choice for an owner.
Scott Whitney (66.214.66.193)
Posted on Friday, March 08, 2002 - 3:58 pm:
I believe the new style valve that I had installed when I had a truck shop put spring brakes on my bus will not allow both the spring brake and service brakes to double the force. But I could be wrong. There are times when I am trying to put my bus on ramps where I sort of let off the service brake while applying the parking brake. I try to do it as a transition without applying both. It seems to work - but I suppose I wouldn't know if I were doubling the force either.
Also, in case of a complete air system failure, on my spring brake chambers, there is a special bolt that can but screwed in to release the brakes to get you off the road if need be.
But I am keeping my Johnson bar just in case! Two brakes are better than one, but three is best, right?
Scott
Al (206.28.236.203)
Posted on Friday, March 08, 2002 - 7:41 pm:
Thanks to all that responded to my Johnson Brake delimma. I currently have ICC brake, no spring brakes which i wish I had. Right now my method of parking is wheel chocks and in gear.
I have only aquired my bus 4 months ago. Thanks to Bus Nuts, I am getting a world of information. Also I don't have power Steering, but did aquire an air assist off of a 4104 from my good friend Luke. So I think I will still pursue the drum.
Sincerly Paco Express.
