Simon Ayriss (Design_dog)
Registered Member Username: Design_dog
Post Number: 33 Registered: 3-2007 Posted From: 69.233.8.116
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 04, 2007 - 1:27 am: | |
Does someone know where I can find any help, a photo or two, or a diagram on a basic bus plumbing set up. It's for a MC8. I want to start to figure out plumbing with emphasis on simplicity and zero problems. I want to get a good fresh water pump and a good hot water heater (probably just propane.) bathroom will be in the common three quarter mark in back of bus. most put plumbing I believe in the back bay? thanks in advance. |
Post Number: 354 Registered: 7-2006 Posted From: 66.217.107.181
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 04, 2007 - 2:15 am: | |
Re: "Does someone know where I can find any help, a photo or two, or a diagram on a basic bus plumbing set up. It's for a MC8. " It could just as well be for a Boeing 707, Simon! The &*$^% has to run downhill, and the fresh water uses a pump.. Just make sure you drill a 1/4" hole (or less), where you're about to place a toilet, sink, etc., and poke a long, identifiable wire through the hole. Then go into the bays, and see where the wire is poking through. You can then decide if it's the best location for what you desire to install.... Plumbing (or wiring) a bus, isn't much different than any conventional home. With electrical, the grounding/bonding is slightly different. But the plumbing remains the same. You'll need proper venting at the drains, to insure the waste goes down. You'll need the proper angle of discharge for the waste, to allow it to go into the tank... Pick up any plumbing book at Home Depot or Lowes, and it'll point you in the right direction. |
James Robinson (Jjrbus)
Post Number: 64 Registered: 12-2000 Posted From: 76.1.180.218
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 04, 2007 - 8:34 am: | |
Only my personal experience. I would find people with conversions, a rally would be excellent for this. Take a camera, ask questions, take pictures. What seems like a simple thing can be really complicated. Most people build fair weather coaches.If you live or plan to visit a friged area it is a good idea to slope supply lines to aid in draining, its a good idea anyway. How about heated holding tanks? Do you want a 3 or 4 inch access to your blackwater tank? Will you want a black and grey tank, or a mixed tank with a greywater bypass? Do you want to be able to dump from both sides of the coach or just one side? It is easy and costs nothing when ordering tanks and doing layout to make provisions for a macerator pump. A bit more to it than a house. If you cannot find a rally at least go look at some RV's HTH |
Don Evans (Doninwa)
Post Number: 35 Registered: 1-2007 Posted From: 65.61.96.82
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 04, 2007 - 12:04 pm: | |
Something you want to consider in the basic layout. If you can, keep the bathroom fixtures as close to the kitchen fixtures as possible with the the hot water tank centrally located. You waste less water waiting for hot water to reach the fixture. Our first bus, already converted when we bought it, had the hot water tank in the very rear and it took a lot of water to get hot to the kitchen sink which was forward more than normal. I would use a hot water tank that has a heat exchanger loop even if you don't use it initially. Definitely hook it up to the engine (free heat) and maybe in the future an auxiliary diesel boiler. Years ago I gave up using RV antifreeze in RVs and boats. I just blow out the lines and have had zero problems. No adding antifreeze and then draining it in the spring. No hot water tank bypass. Just blow it out in the fall and it's ready to fill and go. |
Ray Drummond (Ray_d)
Registered Member Username: Ray_d
Post Number: 15 Registered: 4-2006 Posted From: 69.111.109.215
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 04, 2007 - 12:21 pm: | |
http://www.winnebagoind.com/diagram/Plumbing.htm Here is a link to some plumbing diagrams, they have electrical plans as well. |
Post Number: 120 Registered: 12-2000 Posted From: 67.141.151.126
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 04, 2007 - 2:28 pm: | |
I would consider using a seperate home run from each fixture to a manifold with individual shut-offs. Easy to isolate a problem. Len |
Registered Member Username: Chucks
Post Number: 1110 Registered: 10-2003 Posted From: 68.240.11.124
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 04, 2007 - 3:56 pm: | |
"I would consider using a seperate home run from each fixture to a manifold with individual shut-offs. Easy to isolate a problem." Dat's what I did, but ol' JMC9 tole me my original manifold design looked like Rube Goldberg! I redid it. Just for him. But never showed him the final version. And I ain't gonna either. LOL (Message edited by chucks on June 04, 2007) |
Post Number: 355 Registered: 7-2006 Posted From: 68.205.158.177
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 04, 2007 - 7:00 pm: | |
Jerry Campbell (Jerrync)
Registered Member Username: Jerrync
Post Number: 76 Registered: 7-2006 Posted From: 69.132.150.103
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 04, 2007 - 7:02 pm: | |
I used a Vanguard and love it and used pix lines EEEEEEZZZZZZZ to do |
Post Number: 1111 Registered: 10-2003 Posted From: 68.240.11.124
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 04, 2007 - 7:10 pm: | |
Masters of Inefficiency 2007's winners of the regional Rube Goldberg Machine Contest at Purdue University celebrate after their contraption beat out others to win top spot. The massive device, which successfully poured a single glass of orange juice, was assembled by Michael Stumpf (left), Greg Bauman (center) and Drew Wischer (right). The lads spent 3,000 hours making the machine as inefficient as possible. http://www.wired.com/gadgets/mods/multimedia/2007/05/gallery_rube |
Post Number: 356 Registered: 7-2006 Posted From: 68.205.158.177
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 04, 2007 - 7:56 pm: | |
Chuck - Har de har har.... !! Man... gotta' meetcha', one oh dese dayz. (btw....yer bus is lookin' gooooood, ma'man!) |
airless in Mississippi (Airless_in_mississippi)
Registered Member Username: Airless_in_mississippi
Post Number: 144 Registered: 11-2004 Posted From: 68.242.52.75
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 05, 2007 - 1:10 pm: | |
John How comes you come and take a pic of my plumbing and didnt even bother to say hey>?? |
Post Number: 357 Registered: 7-2006 Posted From: 66.217.108.90
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 05, 2007 - 6:02 pm: | |
My Doc says: "Seen one guy's plumbing; seen 'em all" (HAR) |
