For my 24 volt jump start ???? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » June 2007 » For my 24 volt jump start ???? « Previous Next »
RJmule (Rjmule)
Username: Rjmule
Post Number: 102
Posted From: 75.51.66.117
Posted on Thursday, June 21, 2007 - 1:13 am:
Use series & parallel wiring in combination
This diagram shows a combination series and parallel circuit to increase both the battery current and voltage level at the same time. Assume this time we are using 12 volt batteries.
The left to right series connection add the two 12 volt batteries to make 24 volts. And, since we did this 3 times and then connected each group of 2 (now 24 volts) in parallel we end up with one very large 24 volt battery. It has twice the voltage of a single 12 volt battery and 3 times the current or power because all 3 groups are wired in parallel. Using series and parallel in combination to increase both current and voltage.
Username: John_mc9
Post Number: 390
Posted From: 68.205.165.5
Posted on Thursday, June 21, 2007 - 9:53 am:
Why would you need to, when two 31 series batteries would suffice?
